C5X7_2_2HDI
Donor 2022
Post by C5X7_2_2HDI »
Hello Marc,
I was hoping if you could please provide me with a manufacturer number and a price for hydraulic block on my C5 X7 VIN: VF7**************[VIN obfuscated, can be read by forum staff].
Best Regards!
x 4936
Post by GiveMeABreak »
(1) BHI Suspension Hydraulic Block:
Citroen New (requires configuring) part: 5277P2, £1,906.57
Exchange (requires configuring) part: 1680917480, £1,198.52
C5X7_2_2HDI
Donor 2022
Sorry I meant hydraulic block valve assembly for automatic transmission. My bad
x 4936
No problem:
1) Hydraulic Block
Brand New Aisin, part: 9807295280, £2,356.73
Std Exchange Unit, part: 1612037380, £1,156.76
Rhothgar
Donor 2023
x 70
Post by Rhothgar »
Hope you're having a good Bank Holiday.
Please may I have the part number for the dipstick for the Xantia 2.0HDi RHZ? Mine has crumbled.
x 4936
(4) Engine Oil Gauge, part: 117462, £23.68
Rhothgar
Donor 2023
x 70
Post by Rhothgar »
GiveMeABreak wrote: 28 Aug 2023, 18:33 Image
Thank you Marc.
darbuck
Donor 2023
x 125
Post by darbuck »
Hi Marc can you give me a part number for the fuel rail for my C5 please.
x 4936
(2) Injector Supply Rail, part: 1570L9, £346.85
Note, this also includes the sensor shown at the bottom, which is not available separately from Citroen, as in some cases separating them can cause big problems, so these are factory-assembled as one unit.
darbuck
Donor 2023
x 125
Post by darbuck »
Thanks Marc, Yes I know I think I took my sensor off the rail when I done the engine rebuild so I am just going to replace it with a used one apparently it causes a no start if separated from the rail. I just need to rule it out.
vaho
Donor 2023
Post by vaho »
Hi. I have a part number: 9674063480. Can you please look if there is a picture about the location of that part (GPS antenna) in the car? Citroen DS5
x 4936
You're going about this back to front.
These are the components for your vehicle, let me know the items you require part numbers for. The part you have supplied is not one of those shown:
vaho
Donor 2023
Post by vaho »
It should be part no 3. As I can see it is located in the roof part of the hatch.
x 4936
Not, (3), as not fitted to your vehicle.
Can only be:
(2) Radio Aerial Adaptor, part: 9674062980, £48.84
(4) Radio Aerial Adaptor, part: 9673844580, £34.20
vaho
Donor 2023
Post by vaho »
Yes, it is not fitted but since I retrofitted NAC I need a GPS antenna. Just wanted to know where it is when fitted. Thank you.
