- x 6666
(2) Exhaust Gas Temperature Sensor, part: 1618PG, £187.51
- Donor 2023
- x 18
Thanks Marc
so the module is in the stalk itself ?
regards
regards
- x 6666
I've never seen that other component you pictured. The Cruise Control module is that stalk unit that interfaces with the Comms Unit and the engine ECU / BSI.
- x 239
- x 239
Hi Marc, can you give me the part number for reverse switch for my C5 please? And if possible replacement procedure.
Darren
- x 6666
(13) Reversing Lamp Switch, part: 225753, £22.16
- x 239
- Donor 2023
Hi Can you find a part number for the under bonnet wiring loom of
1997 Peugeot Expert 1.9D bus
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Also is the RHD and LHD loom the same
- x 6666
The harnesses differ on build date, equipment and are different for Left Hand Drive.
- Donor 2023
- x 53
Good afternoon Marc,
Citroen C3
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Please could I have the part nos for:
1. Front NS ABS sensor.. there are 2 lengths, I'm not sure which one I need.
2. At the back of the gearbox( according to the garage ) is a rubber mount preventing the gearbox contacting the chassis. I need this mount no please?
Thanks, have a good weekend.
Citroen C3
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
- x 6666
There's only 2 ABS Wheel sensor parts - one for the front and one for the rear. The sensor shown at (2) is the rear one.
As for the gearbox mounts - this is the engine fixing diagrams which include any gearbox mountings IIRC. So if you can identify it, let me have the item number:
- Donor 2023
- x 53
Thanks Marc, I'll have to use a friend's garage to get under and take a decent peek. I'll get back to you.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 134
Marc,
Can you provide the part number for the Turbo on my C5 x7 ?
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 6666
Exchange Turbo (HONEYWELL INDUS - GTB1449VZ) HONEYWELL INDUS - 806500, part: 0375S8, £851.93
- Donor 2023
Hello, can I put a request in for:
I am after diagrams and part numbers for all of the engine and gearbox mounts please.
