- x 133
Marc,
Looking for the part no for front wheel bearing for C5
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 6373
Here you go Kenny.
(1) Front Stub Axle Carrier (includes all marked items listed under (1))
Left, part: 1640790280, £433.80
Right, part: 1640790480, £473.23
The front wheel hub on its own (3) is part: 330780, £95.58 , but assumed you would need all the associated parts.
- x 133
Thanks Marc,
The wheel hub and part A are fine it's just the bearing item 4 (D + 29).
Kenny
Kenny
- x 6373
No worries
(4) Front Hub Bearing Assembly
Citroen OEM, part: 335082, £137.09
Citroen Cheaper Equivalent, part: 1681930280, £52.42
HI;
Looking for the part numbers for the front lower wishbones, both left and right (C5X7 2.0HDI 2011)
Full VIN: VF7**************[VIN obfuscated, can be read by forum staff]
- x 6373
Citroen Original (Left), part: 9666244080, £462.54
Citroen Cheaper Alternative (Left), part: 1682731680, £212.92
Citroen Original (Right), part: 9666243980, £469.94
Citroen Cheaper Alternative (Right), part: 1682731380, £157.31
Prices include UK VAT @ 20%
- Donor 2023
- x 11
Is it possible to get hold of a parts diagram for a Mk2 citroen dispatch sliding door handle please ? One of mine appears to have lost a 'wear strip' that fits onto a dovetail at the end that pulls out. This means that when it pulls out the handle moves towards the bit with the lock barrel in it by around 1mm, making it liable to slip out from the mechanism and come away in your hand !
I sourced a complete handle assembly, but when that arrived it is also missing this wear strip part too
The part number I found for the handle is 9101GP, but I think that is for the actual handle, not the wear strip bit that pushes over. I'm hoping the diagram will give numbers for the component parts and I can figure it out from there. Th eonly other option is to delve inside the door and hope its fallen down and made its way right to the bottom and is vissible there.
My van is a Toyota Pro-ace, so I'm not sure the VIN will help in narrowing down part diagrams ? I can grab it tonight and add here if it would help.
- x 6373
I can't really help you with a Toyota!, however the door part you mentioned is for a Dispatch III. so then going onto the door mouldings we have this:
If you need part numbers of any items let me know the item number.
The diagram for the rear sliding control that the part number you specified for the door handle is below, so if the bit you want is on this diagram, again, let me know the item number:
- Donor 2023
- x 11
Thanks for the info. I think that a Mk 3 and Mk2 use the same handles on the sliding door. My toyota is a rebadged dispatch Mk2.
I think the diagram confirms that the wear strip that I'm missing is a constituent part of item 3 in the sliding door diagram, and not identified separately. Thats a shame, but I've looked at the handles on our Pug 308, and they a[pear to be identical shape, and have the wear part. They are cheaper on ebay too, so I've invested a tenner to see if I can get that bit swapped across ! I'll pop a new thread in if I manage it, just to record what I find. Might even manage a couple of pics to keep a full record !
Thanks for your help.
- Donor 2023
- x 472
Hi marc, can i have the part numbers for 2 timing belt kits
1st peugeot 207 vin number VF3**************[VIN obfuscated, can be read by forum staff]
2nd peugeot 308cc vin number VF3**************[VIN obfuscated, can be read by forum staff]
Many thanks.
Many thanks.
Husky.
- x 6373
207
(15) Timing Kit (inc. water pump):
Peugeot Original Kit, part: 1684448280, £265.70
Peugeot Cheaper Kit, part: 1684891780, £173.82
Contitech Kit, part: 1689586380, £173.82
Note The kits for your build date also require separately the crankshaft gear (shown ext to item (7)), part: 9810701080, £88.04.
308
Note Timing Kit with pump not available - so listed separately underneath.
(6) OEM Distribution Timing Kit, part: 1608747480, £188.21
(1) Coolant Pump
OEM Peugeot, part: 1609417680, £106.64
Cheaper Alternative, part: 1623095180, £72.17
308
(1) Coolant Pump
- Donor 2023
- x 17
is the cruise control module on my 407 Hdi 2.7 a seperate unit or built into other control units
if separate, where is it located ?
Any part numbers ?
Ebay pics suggests it looks like this but I could not find one for the 407 hdi 2.7
thanks
Any part numbers ?
thanks
- x 1119
Almost certainly just a built in function in the engine ECU / BSI.
- x 6373
The cruise control module is built into the separate cruiser / limiter module in the stalk of the Comms unit in the steering wheel and actioned via the engine ECU. That component you have posted is not a part sold by PSA - they only provide the stalk module itself.
(10) Cruise / Speed Limiter module, part: 6242Z8, £154.04
- x 192
Hi Marc, can you give me the part number for an exhaust temperature sensor please for my c5
Darren
