yannbeam
Donor 2022
x 4
Post by yannbeam »
Hi. Would one of you fine people please look up the part number for the fuse box on my Xantia ? There are a few new old stock ones floating about but I want make sure I get the correct one.
Thanks.
x 4936
Post by GiveMeABreak »
These are not very descriptive (as in there's no actual Engine Fuse Box part), so is it this "15 Fuses Box"?
(1) 15 Fuses Box, part: 6500C6, £120.56
x 659
Post by wheeler »
Or are we talking about the inside fusebox in the dash??
Kunigaikstis
Donor 2023
Post by Kunigaikstis »
Hello, I would like know which boot windshield my car was originally equipped with. I'm sure i could figure it out if I looked at it but unfortunantely it is currently covered up with a taped on trashbag :D
VIN VF7**************[VIN obfuscated, can be read by forum staff]
x 4936
(6) Rear Screen, part: 8744X5, no longer available.
Huskyxantia
Donor 2023
x 250
Post by Huskyxantia »
Hi Marc Im needing to check the dfp fluid type for a 60 plate 308cc 1.6hdi .
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Also a diagram of what im looking for thank you
x 4936
You need Powerflex Additive. There's no diagram of this - it's a fluid, but here is the tank:
1 Litre, part: 9736A0, £85.01
3 Litre, part: 9736A1, £202.38
yannbeam
Donor 2022
x 4
Post by yannbeam »
wheeler wrote: 10 Jul 2023, 11:32 Or are we talking about the inside fusebox in the dash??
That's the one. Its under the dash. Mine has corroded quite badly and is giving loads grief. Thanks.
x 4936
@Yannbeam: Ok, so part is £175.43 from Citroen inc. VAT - still available.
Rhothgar
Donor 2023
x 70
Re: C8 Vacuum Hose
Post by Rhothgar »
Morning Marc.
Could I have timing belt kit, water pump and auxiliary belt tensioner part numbers for X435 JGJ please?
Reason: Moved to Official Parts Thread
x 4936
Registrations are no good to me, please confirm vehicle / last 3 digits from VIN in the case of multiple cars if you've previously supplied the VIN.
However if it's for VIN ending 665, then here you are:
(11) Coolant Pump and Timing Kit:
Original Citroen parts, part no: 1609524780, £349.63
Citroen Cheaper Alternative, part no: 1609120180, £133.46
Rhothgar
Donor 2023
x 70
Post by Rhothgar »
GiveMeABreak wrote: 14 Jul 2023, 11:22 Registrations are no good to me, please confirm vehicle / last 3 digits from VIN in the case of multiple cars if you've previously supplied the VIN.
That is indeed correct.
I doubt it tells you what brand either of these kits are?
Huskyxantia
Donor 2023
x 250
GiveMeABreak wrote: 11 Jul 2023, 19:27 You need Powerflex Additive. There's no diagram of this - it's a fluid, but here is the tank:
Marc, is there any part number for the cover held by 10 mm nuts which covers the additive tank, when my mechanic got under to do the refill he said the cover wasn't there.
x 4936
@Huskyxantia : There is no cover shown on the diagram. Item (6) is the fuel tank Heat Shield, so without a picture I won't know what you are referring to if not this.
Item (6) Fuel Tank Heat Shield, part: 153778, £63.22
Huskyxantia
Donor 2023
x 250
Thanks Marc ,Heat Shield is there ( thank god ) black plastic cover missing will try see if i can find one being broken for parts , this is a golden ticket thing.
