Ha, thanks. That would explain the long standing fault message which apparently has not impact on anything.
- Donor 2023
- x 13
- Donor 2023
Hi Marc,
Would you be able to provide the part number for 21in the attached image please?
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Thanks.
Thanks.
- x 4947
The Diagram has been updated from that one you posted:
(21) Bumper Frame, part: 98106346XT, £151.88
- Donor 2023
Thank you very much as always.
Partner has had a light bump in the car, which we have decided to get repaired ourselves and supply as many of the parts or even do some of the work myself, so I will be calling on your much appreciated assistance.
- x 4947
- Donor 2023
Hello Marc
Would you have available the part number(s) for the electric power steering pump on my 2010 C5 X7. There seems to be a few part number that are compatible....
Thanks,
-Thore
Thanks,
-Thore
- x 4947
Hi Thore, thanks for your Forum donation.
Item (1) Brand new Power Steering Electric Pump, part: 400827, £761.38 (inc. UK VAT @20%)
However Citroen have posted a note that the following is an acceptable alternative for this engine:
"4008 C9 (1) for engine EW7A , EW10A , DV6TED4 PEF"
As you have the DV6TED4 engine, 4008C9 is an alternative if you can't get an original, cost £1153.32.
At least with these part numbers you can undertake a search for a second hand one.
- Donor 2023
Thanks a lot, Marc!
- Donor 2023
Would it be possible to get part number for suspension springs.
- x 4947
You didn't mention front or rear, so here are both:
Front (1) Front Suspension Spring (Marking 1 Blue, + 1 White, +1 White), part: 9806762780, £166.84 ea.
Rear (12) Rear Suspension Spring (Marking 1 Purple, + 1 White, +1 Blue), part: 9809248180, £139.87 ea.
- Donor 2022
Not necessarily a part number but is there a way you could get the paint code? i don't have the sticker on my car identifying what paint it has!
- x 4947
Hi Dylan
You have two-tone metallic paint.
Code is KTH (Thorium Grey Metallic)
EXY (Onyx Black)
EXY (Onyx Black)
- Donor 2022
perfect, thank you once again!GiveMeABreak wrote: ↑27 Jun 2023, 16:21 Hi Dylan
EXY (Onyx Black)
- Donor 2023
Hi there.
Sorry to be a nuisance. I just want to double check if this car of mine has a timing belt or chain?
The mechanic seems to think it’s a chain although I’m quite certain it’s a belt.
- x 4947
It has a timing belt - change your mechanic!
