x 4947
Post by GiveMeABreak »
(1) Original OEM Turbo, part: 0375C8 no longer available.
Exchange Turbo (Garrett), part: 0375F2, £707.18
(2) Turbo Supp Bracket, part: 037753, £45.16
(3) 116438 Turbo Lubrication Pipe, part: 116438, no longer available
(4) Turbo Oil Return Pipe, part: 037933, £55.55
(5) Outlet End Peice, part: 038325, £110.12
(11) Turbo Lube Bolt, part: 116446, £12.94
(12) Copper Seal, part: 038021, £0.79
(13) Oil Return Tube Seal, part: 038033, £2.96
(20) Turbo Lube Oil Filter, part: 1611517480, £4.00
Any other bits let me know.
quintet
Donor 2023
x 26
Post by quintet »
Thank you for that, i have a few options now, some recon, some just second hand turbos and most of the other bits seem readily available.
Donor 2022
x 458
Post by Rp0thejester »
Okay Marc, time to put your brain to the test! Can you supply us C8 drivers with an exploded view of the swirly thingy majic,....thx in advance
x 4947
@Rp0thejester: ?
If you mean the EGR, there's nothing further than what I have already put up previously on the part request response earlier.
Donor 2022
x 458
No, not that part, the swirly thingy majic part which is attached to the block near the intake manifold
x 4947
Intake Manifold Air Distributor
(12) Diaphragm, part: 036394, No longer available.
(15) EGR Solenoid Valve, part: 1628CH, no longer available
Donor 2022
x 458
Thank you, is there a diagram that is breakable in that part?
Donor 2022
x 458
*diaphragm
x 4947
It's a complete unit.
You can get them here Ryan:
https://eurofrance24.com/air-throttle-b ... 8-807.html
Donor 2022
x 458
If I wanted to buy part 15 from somewhere else, it's available then?
Donor 2022
x 458
Just seen your post Marc, thx
x 4947
Yes, just Google the part numbers I've supplied - plenty of aftermarket choices. When I say 'no longer available' it just means not from Peugeot.
tearing hair out
Donor 2023
x 13
Post by tearing hair out »
Hi. I'm almost certain my EGR value, etc, part numbers are the same as Rp0thejester's, so I don't think I need part numbers. However, is there any data on the expected performance of various emission control components - opening position vs engine conditions, say - for things like the EGR valve and other parameters that are tracked by Lexia, please? Or, indeed, diagnostic steps to troubleshoot it?
If so, they might make more sense on this post (or maybe here and there): viewtopic.php?t=75116
Citroen C8 2.2HDi, VF7**************[VIN obfuscated, can be read by forum staff]
Thank you.
tearing hair out
Donor 2023
x 13
Oh, in fact a part number for the fuel cap presence sensor would also be of interest, I think, please.
x 4947
@tearing hair out: Not fitted to your vehicle
