RuiV
Donor 2023
Post by RuiV »
Can you please give me the schematics and part numbers of the cooling system of my 5008 II?
Thank you
x 4927
Post by GiveMeABreak »
If you require specific part numbers, let me know for which items from which Diagram
Diag A Cooling HosesDiag B Outlet Tank
Diag C Water PumpDiag D Expansion Tank
Diag E FanDiag F Radiator
Huskyxantia
Donor 2023
x 247
Post by Huskyxantia »
My vin VF3**************[VIN obfuscated, can be read by forum staff] needing part number for front shocks many thanks
x 4927
(1) OEM original parts have been superseded with replacement shocks:
Part: 9810195380, £97.26
Part: 9810195480, £97.26
Cheaper Peugeot Versions:
Left: 1674698580, £83.77
Right: 1674698680, £83.77
RuiV
Donor 2023
Post by RuiV »
GiveMeABreak wrote:
25 Apr 2023, 16:24
Can you give me the parts for diag's A, B & C, please?
Thank ou
x 4927
I'm only listing main parts as you haven't been specific.
Diag A:
(1) Rad Water Inlet Hose, part: 9812441880, £26.59
(2) Rad Outlet Hose, part: 9812441980, £47.78
(4) Rad Degassing Water Pipe, Part: 9677186380, £13.72
(12) Cylinder Head Degassing Pipe, part: 9812442980, £23.56
Diag B
(1) Water Outlet Tank, part: 9812113780, £181.90
(3) Water Housing Seal, part: 9813021980, £9.35
Diag C
(1) Coolant Pump, part: 9836834880, £152.87
(2) Coolant Pump, part: 1628941780, £127.34
(3) Water Intake Tank, part: 9820174380, £130.78
(8) Outlet Hose EGR, part: 1638153380, £88.79
(10) Water Pump Seal, part: 1628942180, £25.15
Huskyxantia
Donor 2023
x 247
Marc the rear shocks on a 207 are they the type that go through the rear wheel arch into the boot area behind the wheel arch carpet ? And whats the part number for them my vin
VF3**************[VIN obfuscated, can be read by forum staff] massive thanks
x 4927
(1) Rear Damper (to be replaced in pairs):
OEM replacement part: 9811403480, £94.14
Peugeot Cheaper part: 1623315080, £55.50
As for the positioning, does this help:
Huskyxantia
Donor 2023
x 247
Excellent, thanks Marc , cars going to be worked on today so will double check mines against the diagram. Thanks.
Huskyxantia
Donor 2023
x 247
GiveMeABreak wrote:
25 Apr 2023, 23:24
My rear brakes are drum type, would this make any difference ?
Huskyxantia
Donor 2023
x 247
Marc is there part numbers for the engine under tray clips and bolts at all ? Diagram would be helpful peugeot 207 1.6hdi , many thanks.
x 4927
(80) DIAM 16 EP 2 A 4,5, part: 703016, £1.15
(81) (MUL) CLIP part: 703018, £0.28
(83) BOLT H RPL VIS HX M6X100 L20, part: 9809840080, £0.46
(84) (MUL) CLIP, part: 6986A8, £1.67
(85) (MUL) FLANGED NUT 6X100-8-10, part: 871832, £1.15
Edhertz
Donor 2022
x 4
Post by Edhertz »
Hi, Could you please supply the part number for the pump to the regulator hydraulic pipe,
Cheers, Alan
x 4927
Have a look at the following Alan, and let me know the item number of the pipe you require, (if this is the one):
Supply Piping Front Suspension
If it's (1) Hydraulic Fluid Return Harness, it is part: 5270KY, however no longer available from Citroen.
Edhertz
Donor 2022
x 4
Post by Edhertz »
Hi Marc, Thanks for reply. Looks like it's 2 I'm after,
Cheers Alan
