x 6397
Hi Miles, ok, so I'm including all the front geometry diagrams, so you can see what is what, just let me know diagram A, B, C, D and the item numbers you need.
As for the brake pad wear indicator, I have included the under bonnet harness diagram, as Citroen only do a repair for broken wiring. They do refer to a Brake Pad Wear Harness, but I can't identify one - so may be a dealer query on this one.
Click diagrams to zoom.
Diag A Driveshafts
Diag B Front Pivot / Hub
Diag C Anti Roll Bar / Drop Links
Diag D Under Bonnet Wiring
Orbit Motors
x 20
Unread post by Orbit Motors »
GiveMeABreak wrote: 13 Apr 2023, 10:25 Hi Miles, ok, so I'm including all the front geometry diagrams, so you can see what is what, just let me know diagram A, B, C, D and the item numbers you need.
Cheers Marc,
I may be being daft here but can't see any of the bits I'm after, it's the steering rack and tie rods that I would like a look at if possible, unless they are hidden in an extra list within those diagrams? The droplinks on diagram C could be useful however so I'll have those as well!
If it is a dealer query for the wiring repair I'll make my own loom and modify the plug myself as my local dealers are not much use from experience!
Thanks again
Cheers,
Miles
Satisfaction guaranteed or your dent back!
If it just about starts and drives, I'll probably buy it.
1995 Peugeot 306 XLd
2007 Citroën C6 Lignage
2003 Saab 9-5 3.0 V6 TiD
x 6397
Of course I forgot the obvious one!
Diag E Steering Rack Components
(3) OEM Steering Rod Part: 3812E7, 61.78
Cheaper Version, Part: 1682734780, £17.09
(4) Steering Gaiter Kit, Part: 406671, £33.25
(5) Steering Rod Ball Joint Kit:
OEM LEFT, Part: 381765, £115.03
OEM Right, Part: 381766, £115.03
Cheaper Citroen Option, LEFT, Part: 1682735780, £33.52
Cheaper Citroen Option, RIGHT, Part: 1682735680, £33.52
(70) Self Locking Nut (12X150-212-19), part: 4010E3, £3.95
WindyMiller
Donor 2023
Unread post by WindyMiller »
Hello,
After part number, price and availability for rear suspension arm, part number 12 (1)
Reason: Amended Part number info and removed incorrect Diagram
x 6397
Ok, so that's not the right diagram for the vehicle (I'll remove it for avoidance of confusion). Here's the correct diagram:
Item (1) Rear Suspension Arm, part: 5175E9 (NFP). So no longer available from Citroen , but when it last was, it cost £187.36
Dustysweeper
Donor 2023
x 6
Unread post by Dustysweeper »
Hi. Looking for par numbers and pricing for a timing belt kit, water pump and auxiliary belt please.
Many thanks.
danlat1415
x 21
Unread post by danlat1415 »
Hello,
Please could you find the part numbers for the rear bumper parking sensors for my C4 Picasso?
VIN - VF7**************[VIN obfuscated, can be read by forum staff]
My car was hit by an unknown vehicle in a car park, scratching across the back bumper and I now get an intermittent 'parking assistant fault' on the dash.
I'm going to Diagbox which one is potentially damaged, but need to check out the part numbers for prices and availability.
x 6397
Dustysweeper wrote: 16 Apr 2023, 13:48 Hi. Looking for par numbers and pricing for a timing belt kit, water pump and auxiliary belt please.
Many thanks.
There is a choice of 3 options:
(15) Coolant Pump & Timing Kit (includes A, 3, 4 & 5)
OEM Original, part: 1684448280, £259.49
Cheaper PSA, part: 1684891780, £173.81
Contitech Brand, part: 1689586380, £173.81
x 6397
danlat1415 wrote: 16 Apr 2023, 23:26 Hello,
(1) Parking Assistance ECU, part: 1617545780, £298.28
(4) Sensor RR Black (not painted) part: 1609981080, £127.90
(5) Sensor Rear (not painted) part: 1608321780, £157.87
(6) Sensor Rear (not painted) part: 1608472280, £157.82
(10) Proximity Sensor Support Assembly, part: 1609617680, £20.62
Smith92
Donor 2023
Unread post by Smith92 »
Hello,
Could you please help me with the oem numbers for this parts?
My VIN number: VF3**************[VIN obfuscated, can be read by forum staff]
Big thanks for your help and sorry for the long parts list.
Shock absorber front right
Shock absorber front left
Shock absorber dust cover kit
Brake disc front
Brake pad for disc brake (front)
Track rod end
top strut mount bearing kit
Rear axle bush
Front Axle Ball joint
Brake disc rear
Brake pad for disc brake (rear)
Gearbox rubber mount
Wheel bearing (front left)
Wheel hub (front left)
Engine Mount Upper Right
Rocker cover gasket
Thanks again, i am so very grateful for your time :)
x 6397
Note that the original OEM struts have alternative parts now recommended, but they don't state which is left and right - but as you need both it shouldn't matter in the description:
(1) OEM Left & Right Struts
Part: 9810757280, £107.03
Part: 9810757380, £107.03
(1) Peugeot Cheaper Strut:
Left, part: 1674698380, £77.40
Right, Part: 1674698480, £77.40
(2) Shock Absorber Cover, part: 525431, £16.15
(10) OEM Front Shock Mounting, part: 503177, £59.75
(10) Cheaper Peugeot Mounting kit, part: 1638380580, £40.51
(5) OEM Steering Rod Ball Joint Kit, Right, part: 381741, £100.73
(5) OEM Steering Rod Ball Joint Kit, Left, part: 381742, £100.73
(5) Peugeot Cheaper Alternative Steering Rod Ball Joint Kit, Right, part: 1607316280, £16.02
(5) Peugeot Cheaper Alternative Steering Rod Ball Joint Kit, Left, part: 1607316380, £16.18
(1) OEM Original Discs, part: 4249J6, £203.80
(1) Cheaper Peugeot Alternative, part: 1686717080, £129.22
(3) OEM Brake Pads, part: 1647873980, £119.00
(3) Peugeot Cheaper Alternative, part: 1617256680, £34.01
(1) OEM Front Stub Axle Carrier Left, part: 364696, £482.33
(1) OEM Front Stub Axle Carrier Right, part: 364796, £459.42
(2) OEM Rear Hub Bearing, part: 374883, £85.16
(2) Peugeot Cheaper Alternative Rear Hub Bearing, part: 1681933680, £42.74
Note: Rear Brakes can be either Bosch or TRW Lucas. You will have to physically check these to determine which type you need. I have therefore provided the parts for both systems.
Bosch
(1) OEM Wheel Hub Disc, part: 424934, £152.15
(1) Peugeot Cheaper Alternative Hub Disc, part: 1619237880, £102.40
(3) OEM Brake Pad Kit, part: 425476, £83.26
(3) Peugeot Alternative Brake Pad kit, part: 1617272480, £31.21
TRW Lucas
(3) OEM Brake Pad Kit, part: 1647873680, £83.26
(3) Peugeot Cheaper Alternative Brake Pad Kit, part: 1617250480, £22.20
Gearbox Mountings
These are all the mountings - you'll need to let me know which item numbers you require part numbers for.
(9) OEM Cylinder Head Cover Gasket, part: 0249A9, £26.82
Smith92
Donor 2023
Thanks for the very fast help Marc :)
From the 5. picture, could you check for me the separate oem number of the part “B” and number 3 and 7?
I need to double check the mountings which ones that i exactly looking for. I'll be back with the numbers according to that diagram.
Best Regards,
Roland
x 6397
Item (4) Front Hub Bearing Assembly (B & 14)
OEM, part: 335069, £136.67
Peugeot Cheaper Alternative, part: 1681935280, £31.38
(3) Front Wheel Hub , part: 330785, £166.28
Orbit Motors
x 20
Afternoon Marc,
Citroen C3, VF7**************[VIN obfuscated, can be read by forum staff]
A few odds and ends for this one.
Driver and passenger sun visors and any associated parts if they are part of an assembly
Nearside front bumper rubbing strip (the one between the headlight and fog light)
And if possible could you tell me which BSI was fitted to this car? Looking at a possible replacement of the relay side if I can't get the central locking issue sorted.
Many thanks in advance
Cheers,
Miles
x 6397
See my post relating to the central locking issue first on your other thread.
Sun Visors:
(1) Sun Visor Set (left and right included), part: 1611904980, £211.96
(2) Hook, part: 8143SV, £7.76
(70) MUL RLX Screw (DIAM 4,8 X 16), part: 692588, £1.88
(71) MUL CBLX Screw (3,5-19), part: 9675380280, £0.44
Bumper Strip
(3) Protection on Bumper (Left), part: 7452HH NFP (No longer Available)
BSI (but refer to my post on your other thread first)
The electrical architecture on this C3 is CAN CAN.
The BSI is part: 6580NG, £538.70
