Restoration of a Canadian 404C
Mike T
x 10
Re: Restoration of a Canadian 404C
Unread post by Mike T »
This set of five XAS tires and inner tubes cost me £900 from Longstone Tyres, including shipping to Canada!Image
Fuel tank cleaned out in a hot tank and refinished inside and out:
August 2017: ready for paint:
A short while later I brought the rear and front suspension down and helped the shop mount it:
1966 Peugeot 404 Coupé Injection
Register your 404: https://recensement.leclub404.com/submit.php
Mike T
x 10
Back home, late September 2017, after we returned from a trip to Japan.
Restoring ID:
A few other items the shop painted: bumper filler panel, Carrosserie Peugeot tag (mine was the 10758th 404C ever made, of 17,223), under bumper steel spoiler, interior air intake grille.
Mike T
x 10
First batch of plating is back, including chromed steel grille surround, repaired and chromed zinc diecast taillight bezels and cadmium plated hardware: Image
Hood (bonnet) stay and suspension bolts and lockwashers replated and looking very shiny:
Assembled grille:
The badge is new and the anodized grille bars were not refinished.
Mike T
x 10
More stuff replated.
Dashboard assembly begun:
Water pump pulleys: white one is original but I'll use the red one from a 504.Image
x 6626
Fantastic job Mike, and I'm talking about the postings not the restoration which speaks for itself!! :) :)
Dormouse
x 698
Unread post by Dormouse »
Details like trial fitting trims and bumpers before the final coat of paint are useful reminders to anyone working on cars. Detail and Prep like these are rarely covered - you usually only get a before and after set of photos.
A tip for anyone working on a car - take as many pictures nowadays as you can, at all stages. Don't rely on memory to reassemble things weeks/months/years later. And don't rely on diagrams from manuals - they often aren't for your particular car/model or year. 50 years of painting and restoring cars taught me that. Write notes, draw diagrams, and, nowadays, take pictures/videos even if it means using a secondhand phone/camera instead of your pristine Smart phone.
Mike T
x 10
New old stock fuel tank sending unit
Rear badges and lights on
Steering column
More plating and stainless steel trim polishing
Installing cable operated window winder mechanisms
Mounting window trims and seals, new Record brand rear dampers...
Mike T
x 10
Stainless steel side trims mounted
Carrosserie Peugeot tag mounted
Dynamat self-adhering sound insulation is used throughout
New thermostatic heater tap control
Heater core mounted
Wiper mechanism mounted
The trim above the doors and windscreen, next to the headliner, were raw steel and surface rusted, causing bubbling of the vinyl covering. I had them replated and so this will no longer be a problem.
Sill trims welded where they were drilled through and then polished
Mike T
x 10
More assembly
