PAT Pump
x 2832
Re: PAT Pump
Post by GiveMeABreak »
That’s not really going to help.
You should only really do that when you’ve actually replaced it or had it deep cleaned.
Doing that without actually replacing it will muck up the calculations. There are unburnt particles and elements of cerine in the additive fluid that cannot be burnt off along with engine debris and other deposits. It is these elements that eventually caused the blockage of the filter along with the ash.
The mileage you’ve quoted is near the outer limit for replacement of the particle filter anyway. So very sooner more than later it is going to start getting blocked up regardless of regeneration. It’s probably time for a deep clean or replacement.
Forced regeneration is not recommended and only suitable for extreme circumstances. It takes a big toll on the engine components as they are not getting natural cooling from the RAM air affect when the car is moving.
akavintz
Re: PAT Pump
Post by akavintz »
Ive got rid of the errors now, looks like theres an order to executing the "replace the PAT fluid" on the ecus.
I think I repeated the process starting with the PAT ecu and then the ENG ecu.
Messages are gone and DPF symbol dissapeared on dash.
I will shedule some time to remove the DPF and clean it any advice on cleaners? Ive heard oven cleaner is good?
V
x 2832
Re: PAT Pump
You can take into many garages now that offer a cleaning service. You need to be very careful what you use, because the cement that holds the filter in place and the filter itself is very sensitive. Even Halfords offer an in-place clean now - regular or deep cleaning services so you might want to let one of these do it for you.
akavintz
Re: PAT Pump
Post by akavintz »
Is that an in place clean service they offer or do they remove the dpf from the car?
x 2832
Re: PAT Pump
It's an in-place DPF cleaning service at Halfords - details here for you:
https://www.halfords.com/car-repairs/ad ... ntres.html
x 303
Re: PAT Pump
Post by wheeler »
akavintz wrote:
20 Sep 2021, 17:59
Some places do in place or removal & clean, You get a much better clean by removing it & doing it properly. On the DV6 engine its really easy to just remove the whole DPF as it separates from the cat. Many garages use Tunapp kit for DPF cleaning, it works really well & can make the DPF like new again, The problem with using it in situ is you cant see if you are getting a good clear out or not.
x 303
Re: PAT Pump
Post by wheeler »
Just had a look at the Halfords link, dont think they use Tunapp as they say they leave it to soak overnight with the 'deep clean'. Tunapp specifically instructs you not to leave it soaking for any more than half an hour or so.
