UREA warning / not clearing
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Re: UREA warning / not clearing
...sometimes it's the simplest things and the fuses are often overlooked. Fingers crossed.
- My Cars: Citroen C4 Hatchback 65 plate
Unfortunatley the engine warning light has reappeared, (not UREA as of yet) when the mechanic looked at it again this time it was saying somehting about a fault with the injector + - connection more electrical than physical hes cleaned the connections but same error, could it be a faulty unit on the injector? or damage on the wire loom some where.
Im tmepted to buy a cheap replacement injector to see if that rules the issue out somehting like this (sorry for the long url) i do believe this is the part number of the injector for my car adblue injector 9802763880
https://www.ebay.co.uk/itm/133886897297 ... %3A2047675
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
If you are considering this, then I would personally only consider a genuine one.
You can get a genuine one for not much more than that unheard of one you linked to above:
https://www.ebay.co.uk/itm/New-Genuine- ... d32a886182
Thanks Marc, so far ive had no UREA warnings Again just the engline warning light still, would a faulty injector electrics cause this? im guessing a engine warnig light is an MOT fail? (not due till December)
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I'm pleased about that part of it now working, but unfortunately the EML or Engine Management Light is a Major fail now, so I would get it checked before then to be honest:
I think it used to be only where the EML light was on with another specific warning lamp, but it now seems they have become more draconian....:
Engine malfunction indicator lamp (engine management light or ‘EML’)
Turn on the ignition and check that the engine malfunction indicator lamp (MIL) illuminates and then goes off. On some vehicles it will be necessary to start the engine before the MIL goes off.
You need to inspect MIL fitted to:
Defect > Category
- petrol vehicles with 4 or more wheels, not more than 8 passenger seats in addition to the driver’s seat and first used on or after 1 July 2003
- petrol vehicles with 4 or more wheels, more than 8 passenger seats in addition to the driver’s seat and first used on or after 1 July 2008
- gas and bi-fuel vehicles with 4 or more wheels, not more than 8 passenger seats in addition to the driver’s seat and first used on or after 1 July 2008
- Kit cars, amateur built vehicles and American pickups are not required to be fitted with an engine MIL.
(a) Emissions levels exceed the manufacturer’s specified limits > Major
(b) Emissions levels exceed default limits > Major
(c) Lambda coefficient outside the default limits or the range specified by the manufacturer > Major
(d) Emissions test unable to be completed > Major
(e) Engine is idling clearly above its normal idle speed > Major
(f) Exhaust emits dense blue or clearly visible black smoke for a continuous period of 5 seconds at idle > Major
(g) Exhaust emits excessive dense blue or clearly visible black smoke during acceleration which would obscure the view of other road users > Major
(h) Engine MIL inoperative or indicating a malfunction > Major
- My Cars: Citroen picasso C4
Hi
Can you tell me what fuse had gone and where please
OnlinePaul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1381
The EML explanation talks about petrol, gas and bi fuel vehicles. Does this mean that diesel vehicles need to have a second light illuminated and illumination by itself is not a major fail?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Diesels too - the above was for 'Spark ignition' vehicles, there's a whole world of pain for 'Compression ignition engine systems':
Defect - Category
(a) Smoke opacity levels exceed the manufacturer’s specified limit -Major
(b) Smoke opacity levels exceed default limit - Major
(c) Exhaust emits excessive smoke or vapour of any colour to an extent likely to obscure the vision of other road users - Dangerous
(d) Exhaust on a vehicle fitted with a diesel particulate filter emits visible smoke of any colour - Major
(e) Emissions test unable to be completed - Major
(f) Emissions test not completed because smoke levels are significantly in excess of the specified limit values - Major
(g) Engine MIL inoperative or indicating a malfunction - Major
Defect - Category
- My Cars: Early 2018 PEUGEOT PARTNER BLUE HDI CRC
Hi daisydog, do you know which fuse was replaced?
Thanks in advance, Olly
