fake I.F.H.S sphere
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 834
Re: fake I.F.H.S sphere
Where the sphere bleeds or squirts LHM after being removed, it is because the diaphragm has a small hole, and the space in the sphere which normally contains only nitrogen now contains a mixture of nitrogen and LHM. When the pressure is released, it takes a while for the nitrogen/LHM mix to be pushed through the hole in the diaphragm until the pressure is equalised.
so by loosening sphere charging bolt ,there will be some LHM, if diaphragm is perforated.
- white exec
...only if LHM has managed to get through/past the diaphragm.
You can usually tell if the diaphragm is perforated if you try to re-gas it: pressure will not hold,
i found a original ifhs sphere!!
but it is for hydractive models -regarding to ifhs catalog-. can i use it for non-hydractive?
its have good threads and dampers and comes with ifhs box - pack of 2 -
also have spotted numbers on damper
