So - after pumping the diesel out - the car didnt start.... the Battery was dead. Now I know why the car went into Economic mode as soon as the ignition was turned on.
As soon as the starter was on, the voltage dropped down to 10 even if the
And guess what!
After putting in a new battery I could program the gearbox.
Automatic gears now work!
So we wont be scrapping it - not yet at least =)
The DPF is 100% full and the fault code for DPF beeing full with adblue is permanent. So that needs addressing.
Citroen calls this gearbox CFC300P, by the way.
C5 only 1, 3, and 5 gears work, in both manual/auto
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
Re: C5 only 1, 3, and 5 gears work, in both manual/auto
That is GREAT news. As the C series Citroens have a lot of electronics a failing battery can cause all sorts of strange problems.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Orchid70 wrote: ↑02 Oct 2021, 14:11 After putting in a new battery I could program the gearbox.
You don't mention if you followed this when trying to program??wheeler wrote: ↑26 Aug 2021, 19:39 Definitely worth trying a gear & clutch position re programming.[When doing it though its very important to have good battery support as it can sap quite a bit of power doing it. Have another running car connected via jump leads, If the voltage of the battery drops too low the procedure can fail.
- Orchid70
- (Donor 2021)
- My Cars: Citroen C5 2011
- x 5
I did have my BIG battery charger on - the one I use programming ECUs.wheeler wrote: ↑02 Oct 2021, 15:41Orchid70 wrote: ↑02 Oct 2021, 14:11 After putting in a new battery I could program the gearbox.
Citroen calls this gearbox CFC300P, by the way.You don't mention if you followed this when trying to program??wheeler wrote: ↑26 Aug 2021, 19:39 Definitely worth trying a gear & clutch position re programming.[When doing it though its very important to have good battery support as it can sap quite a bit of power doing it. Have another running car connected via jump leads, If the voltage of the battery drops too low the procedure can fail.
So I was sure it would have been anough.
