Front lower wishbone
lexi
My Cars:
x 138
Re: Front lower wishbone
Post by lexi »
Some spannering that Kenny! As comfortable as multi link double wishbone suspension is, there are lots of things to wear and squeaks to chase. Cars used to be like this, Rover 2000, older Honda Accord to name two. Then cheap Mac strut took over on everything, pretty simple. Is your steering rack holding up?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
KennyW
My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate
x 132
Post by KennyW »
The rack is still dry, Lexi
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
viewtopic.php?t=69580&sid=108e4ca2700f9 ... c531e799ca
Part numbers relating to suspension wishbones and axle bushes, bearing mounts etc.
Kenny
KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
x 132
Post by KennyW »
HI All,
As promised a final update re my ongoing saga.
Replaced upper pivot support and test drive done all quiet. :-D
Thought I would have a look at old support, it would appear the lower axle bush was moving partially in and out of it's mounting. This was confirmed by taking 2Ib Percywhat'sit and giving the bush a bash with a 27mm socket out it came with 2 strikes.
Nothing obviously wrong with support but I have NOT checked with vernier gauge to see if it is oval.
After fixing this I decided to bleed my brakes to remove some air front the front in particular. Offside successfully done but the nearside bleed nipple decided to shear off. :x
Kenny
Post Reply
