HELP!!!! Xantia LHM leak with pictures
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 315
Re: HELP!!!! Xantia LHM leak with pictures
If you've got a small bit of rubber pipe just replace the elbow as long as you can reposition the black plastic pipe a little so the 'new' piece doesn't kink.
Pete
- white exec
Pete is right: an elbow isn't essential - a loop of rubber pipe will suffice, if a snug fit (or clipped). A low pressure return.
- Donor 2023
- Lexia Available: Yes
- My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff] - x 378
Thankyou both, i will be trying to sort this out this week, probably Tuesday as i have a week off and can run it over to my trusted garage where i can get it up on the lift to have proper access.
*** Edit If i get the correct internal diameter pipe would it make sense to make it longer than needed and make it more like a coiled spring so there is no risk of pinching if i can work out a way to hold the coil in place ? ***
Colin
Colin
