2004 c5 hdi 110 cooling fan woes FIXED and now running (pg 6 on) .
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: 2004 c5 hdi 110 cooling fan woes and now not running....
After checking all the bsi fuses. Lexia now cannot connect at all to the car..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
I'm done for today.. I think I'll just have to pick up that ecu and bsi off ebay..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Not useually.. You can clear them but they come back. I've never had communication fault without it even trying whay happens is it attempts to clear faults but says faults remain..
Anyway.. I've made an offer on the ecu kit and bsi on ebay.. See what happens.. Get it swap it in.. Then see what next.. I'm convinced its the ecu at fault..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1381
Do you read my post a couple of pages earlier about a similar problem I had with our old Xsara?
Yea I did. I had a go by keeping the lift pump running constantly as a pre check.. The engine still stalled leaving the pump running. So I'm Moee convinced the ecu has copped it
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
I know I don't know much about the fuel system of these cars, but is it possible that (when the pump is primed and the engine is running) the natural action of the engine PULLS the fuel through without needing the lift pump to keep pumping? Isn't there a high pressure pump taking the fuel pressure to a much higher level?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Paul - as per you other post, I'll put up some info on this specific system as fitted to the MK I with your engine. It may help you work out when the fan is operating and when not and which system controls what:
So this C5 has a single 500W Fan with 3 speeds. Below are the normal operating conditions:
Three Speed Fan Unit
Components
Key:
Ignition+: + ignition on
+ BAT: Battery +
Calculating the fan unit speed
The engine ECU sets the fan unit speed instruction depending on the following parameters:
The fan unit is fitted with 3 functioning speeds:
Post ventilation
When stopping the engine, the engine ECU controls the post cooling (slow speed), if the measured engine coolant temperature is over a programmed level.
The fan unit cannot be started in the following cases:
A fault concerning the fan unit (or the slow and fast speed controls) leads it to work in fast speed.
Info | Data |
1st gear | 97 °C or air conditioning in operation |
2nd speed | 101 °c or 17 bar in the cooling circuit |
3rd speed | 105 °C or air conditioning in operation |
Air conditioning cut-off | 115 °c or 30 bar in the cooling circuit |
Warning | 118 °C |
Post-cooling | 6 minutes |
Temperature sensor | Temperature: Diesel injection , Warning , heating/ventilation |
Components
Key:
+ BAT: Battery +
BSI | Built-in systems interface |
1320 | Engine ECU |
1304 | Injection double relay (engine relay unit) |
1508 | Slow speed control relay |
1509 | Fast speed control relay |
1510 | electric cooling fan unit |
1514 | Mid speed control relay |
- Engine coolant temperature measured by the sensor
- Cooling requirement linked to air conditioning, controlled by the B.R.A.C
- The engine ECU controls the slow speed and the fast speed
- The BSI controls the mid speed, depending on the information delivered by the engine ECU via the CAN network (engine coolant and air con circuit pressure temperature)
- Slow speed is obtained by supplying the cooling fan via a resistor arranged in series in the supply circuit.
- Mid speed is obtained by supplying the fan unit via two resistors wired in parallel on the supply circuit.
- Fast speed is obtained by supplying the cooling fan directly.
Post ventilation
- Operation in power latch (*)
- Switching off of the engine ECU electronics
- Engine starting phase
Lexia couldn't run the fan in slow speed in actuator tests.. I also could not make lexia clear faults.. It always tries to but can say faults remain. All I got was no communication possible..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
The engine pump is NOT a pump.. Its a fuel rail pressureiser.. It needs a feed of fuel from the lift pump as its not a pump in itself..Hell Razor5543 wrote: ↑20 Jul 2021, 20:36 I know I don't know much about the fuel system of these cars, but is it possible that (when the pump is primed and the engine is running) the natural action of the engine PULLS the fuel through without needing the lift pump to keep pumping? Isn't there a high pressure pump taking the fuel pressure to a much higher level?
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Was the engine running when you tried the tests? If not try that.
- Donor 2023
- x 3008
Erm, the engine won't run!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
[quote="
Marc..
It ran the fast speed without the engine running.. Then slow speed it just clicked clicked..
As James says.. It won't run.. It starts after its first prime then stalls.. 20 seconds running only.
Marc..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I'm just coming in on the end of this at Paul's request - I wasn't aware it was a non-runner but now I know, that would make sense given the info I posted - the engine ECU controls the slow and fast speeds and the BSI the Mid speed - they all need to be running for the system to work as far as I can see... which may explain why you are getting the fan running with a direct feed, but not via the car as the other components are not running.
Yes of course Mrac. I appriciate your input. I think the engine ecu is dead. I've tried another bsm and I get same results..GiveMeABreak wrote: ↑20 Jul 2021, 20:57 I'm just coming in on the end of this at Paul's request - I wasn't aware it was a non-runner but now I know, that would make sense given the info I posted - the engine ECU controls the slow and fast speeds and the BSI the Mid speed - they all need to be running for the system to work as far as I can see... which may explain why you are getting the fan running with a direct feed, but not via the car as the other components are not running.
I'll get that 40 quid ecu and bsi with key off ebay and see what happens..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
