2004 c5 hdi 110 cooling fan woes FIXED and now running (pg 6 on) .
x 2988
Re: 2004 c5 hdi 110 cooling fan woes FIXED and now running (pg 6 on) .
Post by GiveMeABreak »
The BSIs on earlier models had several versions (levels if you like) which were dependent upon options fitted to the vehicle. The more options and equipment, the higher the level of the BSI required. It is therefore essential to fit like for like to maintain functionality or replace with the top level BSI - but of course you'll need the matched set of Engine ECU and Fobs again.
citroenxm
x 49
Post by citroenxm »
I'm not worried. About that.. The fob bit was easy. I swapped. My. Key blade. Into the replacement fob..
So what's your thoughts on my posted bsi above. My one and eBay one...? No go?
x 2988
Both the BSIs are J01, which are the top of the range BSIs. As long as you have the same part number (which they are in this case: 9651196680) you should be fine. They may have different software versions though, but should be fine for matching and if necessary, you can always get it updated at the dealers if required.
citroenxm
x 49
Post by citroenxm »
If I buy another set.. Incedentally that bsi set shown on ebay is 60 quid.. If I spend that its the last spend. I need to sell it now
But we have come out in it again another 100 miles not egr fault so the ecu that was in it was seriously hurt before I even hurt it...
