Saxo radiator switch
Jonathancilia
x 6
Re: Saxo radiator switch
Post by Jonathancilia »
Idle speed is around 800rpm always cold and hot, it never had a fast idle cable attached to it and no waxstat on the thermostat housing is blocked off with a big allen head plug. It seems to pulse when idle only when engine is warm or hot, doesnt seem to do it when cold.
x 1325
Post by white exec »
Could you post a video of the pulsing warm/hot idle?
Jonathancilia
x 6
Abit hard but ill try as it is intermittent not all the time
Jonathancilia
x 6
Issue seems to be fixed after replacing the injector lines and rebleeding the system, idle not pulsing anymore, and the radiator fan is operating normally now, comes in at the right temp
x 1325
Good to hear it's sorted. Could have been air in the fuel, which was slow to clear.
Jonathancilia
x 6
Do you guys know where i can buy a bare rear axle tube online without exchanging mine? I want to find a good bare axle tube with good pins so i can rebuild my axle
