Finally admit defeat C5 2.0 HDI - someone help!
mark6535
Re: Finally admit defeat C5 2.0 HDI - someone help!
Post by mark6535 »
Ok so I've since worked out (by reading up on here) when certain faults happen (for example me unplugging and plugging things in with the engine running) it stops the egr function among other things...until it's driven hot for 5 mins.
How the f**k are you supposed to diagnose things when the ECU switches on and off things as it pleases 😭
So...egr actuator is working..but still fails actuator test for "soiled actuator"
So when the egr arrives I'll swap it but I'm out of ideas now...I'm gonna go for the "ignore it until it's proper (-expletive removed-)" solution
mark6535
Post by mark6535 »
Just an update, turbo shat itself.
Must of drained easily 1.5L of oil out of the intercooler and hose. Which bearing in mind it must of only ran for 10 secs maximum once it went.
Lesson learnt...don't go against your gut feeling 😭
brhmcmc
Post by brhmcmc »
I have that same problem. Turbo gives high pressure error. Were you able to find the solution?
