C5 2.2hdi non runner
MGmike
My Cars: 59 C6 2.7 Red
56 C6 2.7 Blue
55 C5 II Blue
Plus many MG's from 58 to 97
Oh and a Jag XK8!
x 39
Re: C5 2.2hdi non runner
Post by MGmike »
It appears mine is a bit intermittent!
Charged the battery and it started first time! I'll leave it a few days and see what happens...
Dormouse
(Donor 2022)
My Cars: Peugeot 3008 Hybrid4, Fiat Ducato, Morris Mini.
plus notable cars I have owned :- Studebaker 1921, Daimler Consorts, Mercedes 220 Pontoon, Simca 1301, Austin Metropolitan, lots and lots of Minis, both steel and fibreglass bodied, Fiat 500F, Citroen GSA's, Skoda Estelle 120 Rally replica, DKW 1000S, Triumph Herald Estate, Warwick GT (very briefly)
x 666
Post by Dormouse »
how old is the battery? what kind of driving do you normally do? short, mixed, long journeys regularly?
MGmike
56 C6 2.7 Blue
55 C5 II Blue
Oh and a Jag XK8!
x 39
Post by MGmike »
Hi, the car is new to me but has only done 70k so I guess short and/or in frequent use.
I don't know how old the battery is but it has been changed and it tested as good to very good after the charge. I'll just see how it goes for a few days.
gabrue
Sorry for the highjack, let us know how you're getting on.
Dormouse
(Donor 2022)
x 666
Post by Dormouse »
check the static voltage of the battery before you start next time. If the drop is significantly below 12.6 off the charger voltage after say an overnight or couple of days max then no matter what the battery tester says your battery is most likely not holding sufficient charge. the reasons for it might not just be the battery however. cheers
Doo
(Donor 2022)
My Cars: 2000 Range Rover V8 4.0
2004 Jaguar XK8 4.2
2007 Citroen C4 1.6hdi SX
2012 Berlingo Multispace e-hdi XTR (nice drive :-)
2016 Suzuki Burgman AN650 Executive
I miss my Renault 5 Gordini Turbo....
x 116
Post by Doo »
I'd be very surprised if the battery isn't faulty!
Modern engines (with can bus systems) depend on absolute voltage. So if your battery is at all strange to a full charge, I would be tempted (convinced) to replace it. Both my Range Rover and my Jaguar XK8 like a fully charged (reliable) battery. Otherwise they play up and act the dick, such as refusal to fire, spinning but not starting, starting but flagging up fault codes for fun such as ABS, gearbox or some such. Head scratcher at the time and total time wasting, but interesting all the same.........................
Has anyone seen the plot? :?
Dormouse
(Donor 2022)
x 666
Post by Dormouse »
I think I would replace "interesting" with "frustrating and blind siding"
Doo
(Donor 2022)
2004 Jaguar XK8 4.2
x 116
Post by Doo »
Dormouse wrote: 10 Jul 2021, 10:24 I think I would replace "interesting" with "frustrating and blind siding"
Ha ha ha, true story :-D :-D
gabrue
My Cars: C5 Exclusive 2008 2.2 Touring
London Taxi tx4 2014
Post by gabrue »
Still not going, the code that the garages can't seem to get rid of is the P16A0 engine overspeed recognition. Any more ideas please ?
My Cars:
x 731
Post by wheeler »
What is the fuel pressure on cranking?
Dormouse
(Donor 2022)
x 666
Post by Dormouse »
please check the engine oil level is not too high. this code has popped up in several cases where engines have been overfilled. oil takes a while to settle in engines. ours is supposed to be checked 30 mins after stopping the engine to let all oil reach the sump. too much oil upsets the oil level sensor causing problems
I know this because the day after we bought our car from a Peugeot dealer it cut out and eventually refused to start. The numpties had overfilled the engine oil by just filling and dipping immediately. Turns out the oil was 7/8 mm up the stick when you dipped it properly. This upset the oil level sensor which then caused the cutting out and eventual non starting.
Doo
(Donor 2022)
2004 Jaguar XK8 4.2
x 116
Post by Doo »
Seems leccy gremlins are out... Check the connections of the BSE under the bonnet. Wife's C4 was playing funny and it turned out that parking at work is under trees. Said tree's peed tree bits which (somehow) got into the plastic cover and while the unit is sealed, the fuses aren't. I ended up removing the unit, (took photo's of fuses to help reassembly) removed all fuses, checked and cleaned with a fine file and electrical cleaner (clutch cleaner is same stuff) then set about the fuse holders with a mouse tail file then sprayed with electrical cleaner.
Put it back together and its been fine since....apart from the clutch issue, lol.
Another thing might be same unit, but the multilug connectionsnmay be grotty and peventing that signals getting through. Also, check for chafing loom near the engine, gearbox and bulkhead. finally, check the earth connections. It's not unknown for them to go grotty.
My Berlingo Multispace has several fuses under a cover at the battery + which are bolted down. I had fun with one recently and once again it was simply a grotty connection. But it was enough to stop my tow bar sockets working.
gabrue
Post by gabrue »
wheeler wrote: 22 Jul 2021, 07:40 What is the fuel pressure on cranking?
I have a new high pressure fuel pump fitted which has not made any difference.
Thanks for the input 👍
gabrue
Post by gabrue »
Dormouse wrote: 22 Jul 2021, 08:54 please check the engine oil level is not too high. this code has popped up in several cases where engines have been overfilled. oil takes a while to settle in engines. ours is supposed to be checked 30 mins after stopping the engine to let all oil reach the sump. too much oil upsets the oil level sensor causing problems
Interesting. The car has been running a good few weeks since the oil change but I will ask the mechanics if they checked that.
gabrue
Post by gabrue »
Doo wrote: 22 Jul 2021, 14:09 Seems leccy gremlins are out... Check the connections of the BSE under the bonnet. Wife's C4 was playing funny and it turned out that parking at work is under trees. Said tree's peed tree bits which (somehow) got into the plastic cover and while the unit is sealed, the fuses aren't. I ended up removing the unit, (took photo's of fuses to help reassembly) removed all fuses, checked and cleaned with a fine file and electrical cleaner (clutch cleaner is same stuff) then set about the fuse holders with a mouse tail file then sprayed with electrical cleaner.
Hi, we have tried another fuse box, back and forth and no difference but I agree, electrical!
My Cars:
x 731
Post by wheeler »
gabrue wrote: 22 Jul 2021, 14:59
I understand you have a new fuel pump but what is the actual fuel pressure on cranking? There are other reasons there may not be enough fuel pressure apart from a faulty pump.
Post Reply
