Citroen c3 2006 key fob
danielle90
Re: Citroen c3 2006 key fob
Post by danielle90 »
myglaren wrote:
23 Jun 2021, 21:35
That should disappear when the engine is started. Once it has run for half an hour you should get at least ten minutes without it, unless the battery is depleted and needs a proper charge.
its disappeared thank you
Donor 2021
x 1512
Post by Hell Razor5543 »
Economy mode is a way to protect the battery from being drained too much (with the engine not running). Assuming there are no problems with the car you WILL be able to start her when economy mode has kicked in.
