I done now programming .
Citroen manual C4 PICASSO (B78) - B1KI010HP0 is not correct.
In Diagbox ver. 09.103, in ECU menu, there is no "Reset the counter of the additive ECU to zero".
First ECU must be programmed, adding new additive tank and " adding" value of 0.95l of additive.
Then must be programmed PADDGO additive pump controller -separate ECU and menu- with same parameters: new pump and 0.95l of additive.
When running Global test , there is also for my car UREA tank menu??? Adding confusion. Diagbox was connected to the Citroen servers.
The problem is solved. No errors , no limp mode, auto gearbox is ok.
Changed tank with pump, add 0.96l of Eloy and three pin connector connected to the pump.
Thank you for cooperation!
C4 Picasso B78 2015 additive tank Paddgo without bag
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Re: C4 Picasso B78 2015 additive tank Paddgo without bag
There is some cross-over with what you are doing - there are different operations for different repairs / maintenance and this is where the confusion is.
Of course if you are replacing the tank completely, you will need to initialise it as well as reset the additive counter and prime the fuel system.
The document you are referring to is just for refilling the additive tank, not replacing it.
Glad you have it working at last.
