After leaving the car standing for a week I collected and fitted the Bosch 039's this morning, I left the GP's heating a couple of seconds after the GP bulb extinguished and It started beautifully.
Ive subsequently found if started it as soon as the GP bulb extinguishes from cold there is a small splutter on startup. Is the GP bulb timing predefined or can it be adjusted?
1997 Citroen Xsara TD, fuel leak and starting issues.
- white exec
Re: 1997 Citroen Xsara TD, fuel leak and starting issues.
The GP relay will be adjusting the on-period for the light, depending on 'temperature'.
Temp is sensed either by a link to the coolant temp sensor or engine ECU, or (on early cars) by a temp sensor in the GP relay itself.
The light going out is just intended to signify the soonest possible time to start, with a decent chance of starting promptly. Designed to be as rapid as possible (à la petrol) . Giving it an extra few seconds, especially when cold, is a sensible thing. I wouldn't bother to explore/adjust further.
Well done in getting a good result!
- My Cars: 1994 Peugeot 205 STDT, 1997 Citroen Xsara SX TD.
Gone but not forgotten:
1999 Xsara VTS
1997 Citroen ZX SX TD
1990 Citroen BX TGD Auto
1991 Citroen TXD Auto
1987 Citroen RD Auto
1991 Peugeot 309 GLD - x 2
Thanks Chris, I'm surprised at the difference In GP quality though. I couldn't get is to start without a splutter at all with either the four champions (when working ) or with the two working BERU's in place of two duff Champions, which could indicate the Champions were sub par? I always thought of Champion as a reputable brand?
Well aside from the fuel/air leak, which strangely now appears to be reducing by gradually sealing itself? this chapter is coming to an end.
I purchased this car as a project (in a very sorry state) with a water leak and a brake servo issue / vacuum leak, which with any luck I can get round to addressing if other issues stop manifesting themselves beforehand.
The previous owner had contemplated scrapping it before I made an offer. There is plenty still to do on this Xsara to make it right. Hopefully with the expertise and assistance of FCF I can save this car.
