Heat Pumps, One for the engineers
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1381
Re: Heat Pumps, One for the engineers
If one decides to go for the type that buries pipes in the ground, what sort of minimum depth do they have to be put laid?
The reason is that our gaff in France doesn't lend itself to placing the heat exchange radiators on the outside wall. This is the north side of the house and as you can see it's virtually on the road.
It's not good practice to put them on the south facing walls as they get really hot in summer which leaves ground burial. And here we come to the next problem. The water table is only about a metre underground and this makes digging deeper difficult - our next-door neighbour had many ground pumps running when they installed a sunken swimming pool. What sort of area needs to be available per room or square metre?
- NewcastleFalcon
- x 6890
No personal knowledge Paul but this lot say this
Regards Neilhttps://www.homebuilding.co.uk/advice/g ... heat-pumps
"There are two main elements of a ground source heat pump system: The ground array, which can be either a horizontal grid of pipes, which should be 1.2m below ground level, or two or three vertical boreholes, which are likely to be more than 70m deep."
- Paul-R
- Donor 2023
Well that could be a problem"There are two main elements of a ground source heat pump system: The ground array, which can be either a horizontal grid of pipes, which should be 1.2m below ground level..."
"... or two or three vertical boreholes, which are likely to be more than 70m deep."
- NewcastleFalcon
- x 6890
Brilliant so far, but now that page 2 has been reached I will exit my armchair temporarily and bring into the fold a renowned authority about air sourced heat pumps, local north-east lad George Clarke possibly earning a crust or two from Mitsubishi. Where do Mitsubishi Electric have their Factory....good news...Livingston Scotland.NewcastleFalcon wrote: ↑30 Apr 2021, 09:47 Gas Boilers are soon to become persona non grata, and go the way of the internal combustion engine. The only alternative purported is either direct electric heating or heat pumps ground and air source, together with better insulation.
I could go away and do a bit more research and I probably will, but give me an armchair ride with your own thoughts to get us started.
I will regard the thread as a success with a single response, a page or two would be brilliant.How do they work
Why are they currently so expensive
DIY could you make one in your shed what components would you need
Words are good, pictures, pen and pencil drawings better
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2520
Interesting George but you left out the price. Let's take a look at another of George's comments in another video.
First, remember you still need to fund the full capital cost of the kit and installation and not everyone has a spare £7,000-£10,000 (or more) lying around!
Secondly, (and this is what drives me mad about government red tape!) not everyone that installs an air-source heat pump will qualify for the RHI.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
- NewcastleFalcon
- x 6890
He did say with the grants etc it pays for itself over 7 years ... but I would agree that prices for the gubbins and installations are high. Are those units any more complex than a gas boiler They should be able to churn them out at a comparable price, and if there needs to be a transition period of scaling up, target the assistance at making the things rather than the installations. Again the installation for the air source variety is the type of thing plumbers have been doing for years, hot water tank and an output from a "boiler".
Here's the factory tour at Livingston. I like George I he's a good presenter, pleasant, enthusiastic, informative.
When I had my new gas boiler fitted some thirteen years ago it was a Combi as recommended by the greenies at the time which meant that the tank in the loft was removed, the added cost of a new tank to go with the Ecodan system seems to be around another £2 to 3K.
- Dormouse
- My Cars: Peugeot 3008 Hybrid4, Fiat Ducato, Morris Mini.
plus notable cars I have owned :- Studebaker 1921, Daimler Consorts, Mercedes 220 Pontoon, Simca 1301, Austin Metropolitan, lots and lots of Minis, both steel and fibreglass bodied, Fiat 500F, Citroen GSA's, Skoda Estelle 120 Rally replica, DKW 1000S, Triumph Herald Estate, Warwick GT (very briefly) - x 666
A new 14kw Ecodan heat pump plus cylinder - £9600. Fitting is from £1000 in the Midlands/South Yorkshire area
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
Up to 300% efficiency - what's its efficiency at near freezing temperatures?
- Dormouse
There is a good article on air heat pumps on Wikipedia. No efficiency figures are quoted but in every article I have ever read it says they work at their most efficient in mild climates. They will work at low temperatures but efficiency tails off. How much? No one was ever prepared to say - always a bad sign I think.
- Dormouse
The quoted 300% efficiency ( COP ) is almost certainly against electric resistant heaters - ie electric power consumption of the air pump against direct electric heaters. What it doesn't include is the immersion heaters in the storage cylinder.
Yep, we used one to heat our bedroom for many years and yes, we did get a good heat output at normal winter temperatures but once it dropped below freezing the efficiency ratio was about 1 to 1, in other words a 1kw convector heater would have given the same output. You are then talking about 18p per kwh, electricity being by far the most expensive form of heating. As previously mentioned our oil fired boiler provides it at about 5p per kw. We couldn't afford to heat our home with one, its expensive enough now.
- Dormouse
Interestingly, no one so far has mentioned extracting heat from running stream water.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
I wonder if it would be cost-effective if I were to breach the wall to next door and suck the heat out of their house?
Do you think they would notice?
- mickthemaverick
- My Cars: 70+ former cars (list available) including 11 Citroens, 3 Renaults
Current cars: 2004 Subaru Legacy 2.5 SEn, 1994 Mazda MX3 - x 6066
If you're going to breach the wall Steve it might be simpler just to tap into their radiator circuit with your rads
