I didn't check the temp at the time, but I was only about 5 mins into the journey I'd say so the engine was probably fairly cold. This could be purely coincidental, but it seemed to start after driving up a cobbled street. It really did feel like the gears were popping in and out, and I wonder if that was really happening but as a result of the power stuttering.
[2006] Peugeot 407 SW 6-Speed Auto Slipping Out of Gear?
- My Cars: [2006] 407 SW 2.0 HDi (136) Auto(6)
Re: [2006] Peugeot 407 SW 6-Speed Auto Slipping Out of Gear?
Thanks, I've ordered it. Looking forward to trying it out this weekend! I'll get a 32-bit VM configured and ready.GiveMeABreak wrote: ↑26 Apr 2021, 15:47That one looks kosher.BadIdea wrote: ↑26 Apr 2021, 14:32Thanks. I checked their website and unfortunately it appears that the Lexia kit is out of stock at the moment. I found this on Amazon though which claims to be a Rev C device:GiveMeABreak wrote: ↑26 Apr 2021, 09:27 You really need to make 100% sure it is a full chip revision C kit - beware a lot of the cheaper ones are not and this will give you communications problems with a lot of full CAN vehicles.
Although we are not affiliated, members of the FCF can get a 15% on diagnostics equipment from a popular supplier to members:
viewtopic.php?f=51&t=60112
https://www.amazon.co.uk/Lexia-CHIP-REV ... 613&sr=8-5
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
Just be prepared for a long night, grief, lots of pain - as in pulling 2 teeth out without anaesthetic and palpitations.
These installs can be horrendous. Be aware that there may well be additional issues with a VM install - specifically comms issues with the required USB drivers needed for the VCI, firewall blocks and such.
In the end I borrowed a really old laptop with a dead battery from a friend. It took several hours to install, but it did seem to work! I gave up trying to retrieve the faults log as it was still processing half an hour later, but I did manage to pull some faults from the report tab (I've left out the data with no faults present):GiveMeABreak wrote: ↑27 Apr 2021, 12:59 Just be prepared for a long night, grief, lots of pain - as in pulling 2 teeth out without anaesthetic and palpitations.
Code: Select all
Global test :
Date and time : 2021-05-31 13:59:25
ECUs present
BMF : Built-in Systems Interface
Response data
R61809642825280000496557083800700FFFF054047687099
R61FE89E9000004AF020206FF000709020206FE02000002612368
R61B056463336455248524A3231343438303139
R61CA00189ECDFFFF00610062
State of the ECU: BSI
Reference 1 : 9642825280
Reference 2 :
Faults present : 1
CBB3 : boot fuse box: Boot light control fault.
Characterisation : open circuit.
Status :
Variables associated with the fault
BSC : Boot relay unit
Response data
R618C9644332680000496561481800000FFFFFFFFFFFFFFFF
State of the ECU: BSC
Reference 1 : 9656148180
Reference 2 :
Faults present : 1
CBB3 : Fault-boot lighting control
Status :
INJ : Engine management ECU
Response data
R61FE0000000004300102060289010A010206FE00000001622734
R6180965553408000049655534080FFFFFFFF0201FFFFFFFF
State of the ECU: HDI_SID803A
Reference 1 : 622734
Reference 2 :
Faults present : 9
P1445 : fuel additive system
Characterisation : maximum threshold of additive in the particulate emission filter reached
Status : Permanent fault
Engine speed : 0 rpm
output injected : 47.29 mg/impulse
engine coolant temperature : 51 °C
vehicle speed : 0 kph
battery voltage : 12.20 Volt(s)
Engine status : Engine off
time elapsed since ignition positive : 6 seconds
supply voltage of sensors : 60.211 Volt(s)
supply voltage of sensors : 15.05 Volt(s)
ECU load : 0 %
Injector control voltage : 00.00 Volt(s)
+ ignition on voltage : 0.00 V
P1434 : fuel additive system
Characterisation : Diesel additive pump
Engine speed : 800 rpm
output injected : 9.25 mg/impulse
engine coolant temperature : 44 °C
battery voltage : 14.24 Volt(s)
Engine status : idling
time elapsed since ignition positive : 90 seconds
Total quantity of additive contained in the particle filter : 8.03 g
status of the additive system : minimum level of additive reached
historic type of driving : moderate town
Status of the regeneration : regeneration problem
P0461 : fuel additive system
Characterisation : Fuel sender information invalid
Fan unit speed setting or fan unit high speed setting : 1 %
Fan unit low speed setting : Yes
air conditioning authorisation : ?
air conditioning request : Yes
Fan unit : Inactive
air conditioning pressure : 0.243200 bar(s)
supply voltage of sensors : 309.729 Volt(s)
P1435 : fuel additive system
Characterisation : Fault - Additive system
P2408 : fuel additive system
Characterisation : Fuel filler cap signal fault
Accelerator pedal position, track 1 : 50 %
Accelerator pedal position, track 2 : 50 %
Main brake : Released
Redundant brake : Released
clutch : Released
air conditioning cut request : Inactive
Fan unit : Inactive
additional heating 1 input : Inactive
additional heating 2 input : Inactive
engine load : 0 N.m
ESP request status : ?
+ ignition on voltage : 13.22 V
P2137 : Accelerator pedal signal
Characterisation : Consistency with other accelerator pedal signal
Status : intermittent
output injected : 0.00 mg/impulse
engine coolant temperature : 25 °C
battery voltage : 0.34 Volt(s)
time elapsed since ignition positive : 3 seconds
Accelerator pedal position, track 1 : 0 %
Accelerator pedal position, track 2 : 0 %
clutch : Pressed
Fan unit : Inactive
engine load : 4 N.m
ESP request status : not present or pressed
+ ignition on voltage : 8.81 V
P0495 : Cooling function integrated into the ECU
Characterisation : Consistency between speed of fan assembly and reference
Engine speed : 864 rpm
output injected : 12.34 mg/impulse
engine coolant temperature : 7 °C
battery voltage : 14.13 Volt(s)
time elapsed since ignition positive : 20 seconds
Fan unit speed setting or fan unit high speed setting : 100 %
Fan unit low speed setting : No
air conditioning authorisation : Yes
Fan unit : Inactive
air conditioning pressure : 4.134400 bar(s)
supply voltage of sensors : 5.027 Volt(s)
P0692 : Fan assembly high speed control
Characterisation : open circuit or short circuit to earth
output injected : 11.31 mg/impulse
engine coolant temperature : 8 °C
time elapsed since ignition positive : 25 seconds
Accelerator pedal position, track 1 : 6050 %
Accelerator pedal position, track 2 : 25 %
Main brake : Pressed
clutch : Released
Fan unit : Inactive
engine load : 1 N.m
+ ignition on voltage : 0.11 V
P0686 : Power relay control
engine coolant temperature : 2 °C
battery voltage : 1.58 Volt(s)
supply voltage of sensors : 1.245 Volt(s)
supply voltage of sensors : 4.63 Volt(s)
ECU load : 2 %
Injector control voltage : 3085.11 Volt(s)
+ ignition on voltage : 8.59 V
AUTORADIO : Radio
Response data
R6180964687167700039659142777061C050402404726369A
State of the ECU: AUTORADIO
Reference 1 : 9659142777
Reference 2 :
Faults present : 1
F905 : fault on auxiliary audio input n° 1.
Characterisation : not characterised.
Status :
PORTEP : Passenger door module
Response data
R61809646593280002896465945800908250E014047992999
State of the ECU: EDPP
Reference 1 : 9646594580
Reference 2 :
Faults present : 1
CC0E : mirror de-icing output fault.
Status :
- moizeau
- My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped) - x 315
Looks there is a regen problem, amongst other things.
Have a read through this and see if it's similar
viewtopic.php?t=60390
Sorry it's a long thread.
Now that you've got the fault codes that are logged you need to clear the faults and re run the global test. Some of the faults could be very old and weren't cleared. Once you re run the test look at the codes that are current.
I notice the log said 'moderate town driving', does it ever go on a blat down the motorway?
Pete
Thanks, I'll have a read. I did wonder about clearing the faults, but would that matter for the ones that are marked as "permanent"?moizeau wrote: ↑31 May 2021, 17:21 Looks there is a regen problem, amongst other things.
Regarding the type of usage it gets, it really only gets used a couple of times a week at the most and then it's mainly 'B' roads and sometimes 'A' roads. I do take it on 1 hour+ motorway trips every now and then but haven't noticed the regen kicking in (does it indicate anything on the dash?)
- moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
No, it doesn't tell you but can see in Diagbox when the last regen took place. You need to clear the faults then re check to get rid of 'old' ones that will lead you up the garden path. Use Diagbox if possible, not PP.
Pete
Yeah, I'm using Diagbox 7.83. I'll try clearing the codes and see what turns up again. Probably a good idea for me to check the DPF stats then, where do find them in Diagbox? It does say "regeneration problem" in the fault report.
Okay, this morning I cleared the codes and took the car out 25 miles and then back 25 miles a few hours later. A good portion was motorway driving. I read the codes again once I was back and got seven engine management faults:
Is it looking like the DPF needs replacing?
Code: Select all
Global test :
Date and time : 2021-06-03 15:50:22
Response data
Reference 2 :
Faults present : 7
engine coolant temperature : 26 °C
time elapsed since ignition positive : 45 seconds
ECU load : 0 %
time elapsed since ignition positive : 48 seconds
air conditioning authorisation : No
air conditioning request : No
Fan unit : Inactive
air conditioning pressure : 16.051201 bar(s)
battery voltage : 14.01 Volt(s)
clutch : Released
Fan unit : Inactive
engine load : 1 N.m
Engine speed : 1632 rpm
output injected : 15.42 mg/impulse
engine coolant temperature : 40 °C
vehicle speed : 22 kph
battery voltage : 14.35 Volt(s)
Engine status : engine under load
time elapsed since ignition positive : 91 seconds
Fan unit : Inactive
air conditioning pressure : 0.364800 bar(s)
supply voltage of sensors : 63.867 Volt(s)
clutch : Released
Fan unit : Inactive
engine load : 0 N.m
- moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
Not necessarily, it also says that the additive is low (this is 'guessed' not physically measured) and the fuel flap sensor (which tells the car when you've put fuel in) isn't working. Have you looked at when the last regen occurred? I think this is in 'injector ECU' but may be wrong. regarding the first 2 someone with more knowledge will need to chip in as I've never had issues with these. While you've got Diag plugged in it would be worth doing the actuator tests on the air inlet butterflies.
Pete
I took the car to a Peugeot indie last week who found it strange that the engine management light wouldn't be on based on the list of faults, but then found that a function had been deleted to mask the problem (great - I'm assuming this was the garage I bought it from).
Anyway, they changed the fuel filter (apparently it was pretty bad - I guess the most recent service from the aforementioned garage wasn't very thorough), added 2L of additive and reset the DPF status. So far so good, although time will tell as the problem was very intermittent. They also said that the fuse box was corroded and could be causing some of the electrical gremlins. They've said that if I can source one - part no. 6500CG - then they'll fit it free of charge. The problem is that Peugeot no longer do it (same with the additive as it happens - I guess shelf life isn't a priority!), so I'll have to find one secondhand I guess.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Part 6500CG is very much available from Peugeot. I've just checked parts live and is not showing as NFP. It is £273.71 inc, VAT new.
One left in stock at Eurocarcare here for £244:
https://www.eurocarcare.net/bulbs-fuses ... e-box.html
Thanks, I wonder if I was mixing up what he told me. Yikes at the price though!GiveMeABreak wrote: ↑22 Jun 2021, 10:50 Part 6500CG is very much available from Peugeot. I've just checked parts live and is not showing as NFP. It is £273.71 inc, VAT new.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Yes, but bear in mind you are paying for a brand new one - a second hand one may have faults / failed relays or other issues. I can also tell you that there was a problem with some of these fuseboxes that required replacement - I can't remember now, but a failure of one of the internal switches led to several fault codes being displayed and the official resolution was a fusebox replacement on the 407.
Okay, I think I'm just going to pull the trigger on this one based on recent problems with the car.GiveMeABreak wrote: ↑22 Jun 2021, 10:50 Part 6500CG is very much available from Peugeot. I've just checked parts live and is not showing as NFP. It is £273.71 inc, VAT new.
Is this part OEM?
