@wheelerwheeler wrote: ↑13 Mar 2021, 15:18Yes they are 2 different things, when you replace DPF (or have a proper clean done on it) you go in via diagbox in the engine ECU then the pack repair menu & select replacement of the particlate filter this will reset the DPF load back to zero.maverickmk wrote: ↑13 Mar 2021, 13:52Much appreciated Paul.
Is resetting the ECU for a replaced DPF different from resetting the DPF additive counter? I have v7.** Diagbox and could give it a try. I did the additive reset in the past, but I'm unsure how the DPF reset is done (if at all possible).
On this engine its pretty easy to remove the DPF for cleaning, I always try not to disturb the metal pipe going into the DPF as they can snap off, instead I disconnect the pipe from the rubber hose that it attaches to & leave the metal pipe in situ.
Thanks that's really useful to know. Can I interest you in the job cleaning or just replacing as I already have a new DPF? I can come to you depending on how far you are from Kent.
