This is my thinking on it too, means i can also throw the 4gb one in too & if it works then bonus, if not then take it back out.
PC RAM
- x 449
Re: PC RAM
- Donor 2022
- x 42
- x 942
Re: PC RAM
How very unusual, I didn't know that.
Very true.
- x 449
Re: PC RAM
So stuck an 8gb stick in & the PC recognised the 12gb in total. Definitely a massive notable difference, crucial says I can go up to 16 gb so might get another 8gb stick to replace the 4gb one.
- Donor 2022
- x 189
Re: PC RAM
Unless you've got a very high end laptop you probably won't see any further gains increasing ram further, the bottleneck will have moved. You can check this in 'Task Manager' the click on 'performance'. This page will show you how much Ram, CPU is being used.
- x 942
Re: PC RAM
My next move after doubling the RAM to 8GB in my laptop was to change the spinning discs hard drive for a SSD. That really had a quite noticeable effect on boot-up time and general responsiveness. I might go to 16GB next or, just possibly, change the CPU if it isn't soldered to the motherboard.
When I did this some ten years ago on my then laptop I changed from a 1.5GHz Celeron to a 1.7GHz Pentium M and that made quite a big difference. Theoretically there is an upgrade path for the processor which I researched a few years ago. That had something like a 90% chance of working - not soldered to the motherboard permitting.
