S2 Xantia - No lights on dashboard
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 81
Re: S2 Xantia - No lights on dashboard
What have you done to me?
It’s like I’ve opened Pandora’s Box!
Getting the connectors removed has ran me out of plasters...
And inside! Well!
Where do I start?
I can see some dry joints on the top surface but I’m left wondering if I should separate both layers and check for other dry joints on all sides?
A good couple of hours work I reckon taking it steady...
So pleased really though that you suggested this.
And inside! Well!
Where do I start?
- Donor 2023
In fact, I don’t think it’s easy to split that board unless you have a reflow oven and compatibility to manually handle the component whilst still in an oven.
So for now I am going to reflow all the ones I can see with lead solder.
If I hear to the contrary, in the meantime, then all I can do is go with that methinks.
Happy to be enlightened further though.
- Donor 2023
xantia_v6. You absolute genius!
Add another car to your list that have suffered this problem.
Started the car and then decided to cut the solder wire whilst sweating like a bomb disposal expert. Car continued to run.
I could see minute stress fractures in some other solder joints so I licked them up with a bit of flux and reflowed with a bit of extra solder. Only had lead-free to hand anyway.
Another job done together with the leaky front O/S strut return pipe.
Next the speedo binnacle is coming out to effect that repair whilst I’m on a roll.
Then, at some point, refit all the interior bits I have stripped out, buy and fit window regulator repair kit for front O/S, repair cabin temp sensor and I think it might need a heater matrix at some point (can’t quite remember).
Probably regas all suspension.
Some of that work can wait to make sure it passes MOT before I spend another beam on the car.
Back friends with the car. Not quite in love yet. That may take some time to rebuild trust.
- CitroJim
- x 6204
- Contact:
Roger, that's great news
- Donor 2023
- Lexia Available: Yes
- My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff] - x 378
Good result Roger
Side note if the only issue with the binnacle is the rev counter needle at max then somewhere in my grey matter a simple way to fix it is use a thin wire pushed through the hole for the trip reset button and after lots of swearing flick it back to zero.
Colin
Colin
- white exec
- Donor 2023
I've tried those guys. I'll do a fresh post just in case there's more untapped knowledge out there.
So the car is fixed but I have no illumination on the dash. I've checked all the bulbs and about 5 or 6 are blown so need to check something simple like a fuse maybe!
- Donor 2023
When you say Dash do you include the radio and heater panel ?
Have you taken the wheel out and not re connected it ?
Sorry by wheel i mean the dimmer wheel under the steering wheel housing
Colin
**Edit**
If you have the binnacle out replace the whole lot, been there and put it back and 2 weeks later one of them blows that i did not replace
Colin
**Edit**
- Donor 2023
Oh Colin. Yes I disconnected the dimmer wheel to do the wiring checks for the non-start fault.
Now where's that faceplant emoji?
Ah yes!!!
Deserves 3 methinks.
As for replacing all the bulbs. Really? There's 31 in mine!!! They're a £1 each for Lucas.
Before I delve in and check which fuse it is, I'll replug the dimmer in. What a total clown! Would never have thought of that.
Be interesting to hear your thoughts on the rev counter post too. I think taking the needle off will solve it or some of it...
Thanks again.
Ah yes!!!
Thanks again.
- Donor 2023
All done! They're fine with the dimmer switch back in.admiral51 wrote: ↑28 Feb 2021, 18:56 Have you taken the wheel out and not re connected it ?
Colin
**Edit**
On the subject of the bulbs, I've checked them all with a jewellers loupe and some are intact in that quantity I've mentioned but have blackened glass so I will definitely be changing those unless I can find a bargain bundle of 31 bulbs. Don't want to really be buying Chinese though and fingers crossed that others don't go.
Let's hope the speedo is working right now. Got the rev counter working on spec.
Been a good day at the office.
- white exec
Rapid Electronics (and others) will sell those small capless (T5) bulbs, 1.2W for instrument illumination, but 14v, which will have a longer life than cheapo 12v.
- Donor 2023
Oh that’s interesting.
I thought they were 286 unless T5 could be simply another denomination. I’ll double check.
Found some Lucas 286 on Ebay for £2.95 for 10. Does make me question whether they are genuine at that price.
EDIT: Yes. A quick check reveals they are the same.
- Donor 2023
All i can say Roger is ..............
Colin
Colin
- Donor 2023
Spoke to MOT Station today and they are ordering me a complete set in for next week.
One more quick question though if I may.
May dash has around 10 empty holes? Should all holes be filled in a PCB or does it depend on the HDi model?
- Donor 2023
Roger i would suggest you get the MOT done first and then replace the missing bulbs.
If you have the binnacle out i would recommend you shine a torch behind it as this will show the warning symbols that are missing a bulb. It would not be unusual for a previous owner to remove a bulb from an unused slot to replace a blown bulb.
I would guess that all binnacles would come complete with all bulbs from the factory as standard.
Colin
Colin
