I have just bought a DS5 and wasn't able to find one with the HUD fitted but it looks like they are relatively cheap online. However, is it even possible to retrofit a unit onto a car not originally spec'd with one? Are there more alterations that would have to be made?
Thanks, obviously new to the world of big French cars so any help would be greatly appreciated!
Thanks!
Retrofitting HUD to a DS5
- x 6950
Re: Retrofitting HUD to a DS5
They were originally only fitted to the DS Sport with the Citroen badged versions. They were basically unchanged under DS apart form some styling and equipment changes.
It's unlikely you will have the correct fascia wiring harness to support the system as there are a considerable number of harnesses available depending on equipment, trim and options. Then there will be the correct configuration of the BSI and associated ECUs.
