Fap soot load 150 %
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
Re: Fap soot load 150 %
If you do a search on the Forum you should find that people have managed to safely clean the DPF by removing it and then soaking it (I believe, in oven cleaner; but I am NOT certain of this). Then you run water through it until it runs clean (do NOT use a pressure washer, as this will damage the DPF).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- My Cars: C5 X7 2008 2.0 Hdi
- x 3
I have look that soot load value again. Today I take car to highway and look at the numbers. Soot load % was over 150 again. I parked car and let it been there for a while; probably half an our or so. After that I start to drive back home and suddenly my phone beebs five times. I wonder, what a.... Engine has cooled a bit and I drive at 50 - 60 km/h.
Anyway regeneration has started. Heat get over 640 degrees and soot load goes to 160 %. Few minutes of that and next time, when I check the phone, values were going down. Temperature was 250 and soot load was 0 %. Amout on eolys was also a bit redused. So everything seems to be in order .
