I think I looked under all the sections when it wouldn't come up under BSI, but I will certainly have another look tomorrow. ThanksGiveMeABreak wrote: ↑15 Jan 2021, 13:07You can also try looking in the customer options section of Lexia - sometimes the key programming is in there.
BSI problems I think?
Re: BSI problems I think?
Yes mate, that is what I did. Run Diagbox > Citroen > Model > Then I get option of Lexia or Scantool. Lexia > Global Test
I then get a few options BSI, Fault Log, Airbag, Switch Module, Radio etc. I select BSI
I then get more options but nothing to programme the keys.'
if I If I run a fault test on BSI I get the message 'Intermittent Fault. Transponder Identifier not Received'.
I was wondering that there is a fault with the BSI. If Lexia can't communicate with transponder it won't give me an option to programme. And I can't perform a BSI reset as the keyfob RF is knackered.
- x 215
What makes you think you can't do a BSI reset without a working fob? You don't need a working fob for this.
Your old key starts the car so the transponder & reciever are both working but even if they weren't you would still have the option to program keys. It is in a sub menu of the BSI so may not be on the front page when you are in BSI
I'll check all sub sections over the weekend and revert.wheeler wrote: ↑15 Jan 2021, 20:40What makes you think you can't do a BSI reset without a working fob? You don't need a working fob for this.
RE: BSI Reset. The only way I know is with a working keyfob.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Can you advise of a BSI reset procedure where the RF function is not required?
- Donor 2020
- x 708
The last two steps aren't actually part of the BSI reset procedure, they're the remote lock/unlock pairing procedure. So just stop at line 5 for the BSI reset.
- x 2345
We have published a more comprehensive one here that we use:
Thanks Marc, will have agood read and give it a go over the weekendGiveMeABreak wrote: ↑16 Jan 2021, 00:07We have published a more comprehensive one here that we use:
- Donor 2020
- x 708
The problem with Marc's procedure is that it is the absolute complete method covering many different configurations and also includes the remote lock/unlock pairing procedure.
- Donor 2020
- x 708
- x 2345
I've had no complaints to date about my guide and saves me time replicating 3 different ones to suit the relevant systems that a member may or may not have. I hope it is easy enough to follow the relevant sections as applicable.
- Donor 2020
- x 708
Not a criticism Marc, just an explanation of why it's so long. But mainly the fact that it's not absolutely necessary to pair the lock/unlock buttons as part of the process.
- x 2345
No problem. I may revisit it again soon and try to further simplify it.
- x 1340
