white exec wrote: ↑21 Jan 2021, 18:57Slow/lazy starter motor - check main battery connections: if either terminal/clamp gets at all warm during cranking, replace the clamps with new brass ones, as they have acquired resistance internally.
Check also main battery-engine/gearbox-chassis main earth/ground cable for clean connections, and main Batt+ connection to the starter solenoid.
Use a second (jump-start) battery as well. If that speeds things up, replace the battery.
Thanks will check the connections and earths tomorrow and see from there
