xantia rescue
- Scottculli
- My Cars: 1998 Xantia exclusive
- x 25
Re: xantia rescue
hey Jim. this morning the weather has been dry so I took a good look at the break doseur to try and find the leak, it look as thought the top return pipe is the one that is causing the loss of fluid, I've been reading all the posts about how to try and fix it, and it says the best way is to remove the carpet and the bolts should be either side of the break pedal, the only problem is that the break pedal completely stopped me from getting my wrench to the bolt on the right, I was wondering if the was a trick that you knew off to get to the bolt as I cannot for the life of me see how to undo it, thanks Scott
- Skull
- My Cars: Citroën Xantia XII HDi
Citroën sAXo XII
Missing AX 1.4D Echo - x 225
Re: xantia rescue
Scottculli
I haven't had the pleasure yet but have heard most people say that they cut the bolt holding the brake pedal to remove it, then when they replace the bolt they insert it from the other side due to the clearance issues you are encountering .... good luck
On my 4th Citroën Xantia (X2 HDi (110))
Citroën sAXo Memphis Mk II
Gone
Xsara HDi VTR Coupe / Saxo 1.1i / BX 1.9 d / 4 x AX's (1.4D /1.5D)
2 x 406 (1.9 TD Estate/2.1 TD Saloon) 405 1.9 D Estate 306 1.9 XTDT Hatch
Gone
- Scottculli
- x 25
Re: xantia rescue
To be fair drastic measures wouldn’t surprise me at all, I've been upside down all morning with my head in the footwell just trying anything it really is a peculiar design for sure, if nothing comes to me I could just try and snip the clip to the pipe with it still attached to the car and just work using my hands, thanks for the idea it gives me a option to try.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Re: xantia rescue
You might also want to check the clip on the clutch pedal. They have been known to break in the past (especially if it is the older design). I believe (but I do NOT know) that the white/cream clip is the later design.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Scottculli
- x 25
Re: xantia rescue
luckily I've got an automatic, and I get a littlie more room to work with .Hell Razor5543 wrote: ↑21 Jan 2021, 11:43 You might also want to check the clip on the clutch pedal. They have been known to break in the past (especially if it is the older design). I believe (but I do NOT know) that the white/cream clip is the later design.
- Skull
Citroën sAXo XII
Re: xantia rescue
Scottculli I believe it's designed that way to stop the bolt falling out and the brake pedal falling off .... I know what I'd rather
Gone
Gone
- Donor 2023
- x 3008
Re: xantia rescue
I think it may have a nyloc nut on the other end.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Scottculli
- x 25
- CitroJim
- x 6204
- Contact:
Re: xantia rescue
That bolt has possibly caused more blue air than any other on a Xantia
As an aside, I once did a 1.9TD clutch clip by lying upside-down in the footwell, whilst cursing and struggling with the bolt the driver's door closed on me and I was trapped I had to wait for my girls to come home from school to free me
They found it hilarious and so did I once I extracted myself...
- Skull
Citroën sAXo XII
Re: xantia rescue
Jim That would have made a great ''You've been framed'' video and compensation for your trouble
Gone
Gone
- Scottculli
- x 25
Re: xantia rescue
hey it could have been worse, they could have just remembered what they wanted as a early Christmas present, on the condition of letting you out.CitroJim wrote: ↑21 Jan 2021, 17:51 That bolt has possibly caused more blue air than any other on a Xantia
- Scottculli
- x 25
- CitroJim
- x 6204
- Contact:
Re: xantia rescue
They don't need to, even as adults they have me well wrapped around their little fingersScottculli wrote: ↑21 Jan 2021, 19:17 hey it could have been worse, they could have just remembered what they wanted as a early Christmas present, on the condition of letting you out.
Good job I love 'em!
Even I'd enjoy watching it againScottculli wrote: ↑21 Jan 2021, 19:28Something tells me for a fact that would be the most taped tv show in the house after that
- Scottculli
- x 25
Re: xantia rescue
hey everyone i was hoping i could get some advice on the break problem I'm having, for the life of me I cannot see the solution or maybe there's just something simple that I'm missing, but the way to get it out is just is baffling to me. I can see the two 11mm nuts in the footwell the first one is simple enough, but when it comes to the second one I'm trumped, the break pedal stops me from fitting a wrench in there and the strengthen on the side stop me from getting it on a different angle, I was hoping that any of you that had tried this out before what was the procedure you used.
thanks Scott.
thanks Scott.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
