Only if you are working for MI6
xantia rescue
- x 6
- x 6
Re: xantia rescue
hey everyone, so I've got some good news. the engine started today, it took a couple goes but she did it (I've got to say I've had a couple of sleeps since she was last running but my god the noise that comes out of the exhaust its like lovely kind of purr) . then I gave it a couple of minuets for the for the pressure in the hydraulics to build up. I then put it through a couple of cycles of citrobics(although the brake pedal was stuck and really didn't want to budge)and that was all fine .so now that we've got the suspension up its now possible to see where the problems are. so i had a look underneath the car and the was quite a puddle on the near side front strut, when its liter tomorrow ill get it on some jacks and try to narrow it down to a specific location . another thing now the suspension is raised I've been able to take a proper look at the strut tops the left side looks very worn but not terrible but the right side (well those of a sensitive disposition do be advised to look away now)
. but it feels like its in a good place and I'm gona try asking my grandma if I can use her garage, as it would be nice to have somewhere dry to work, all is going good and ill keep you all informed in how it comes along.
- Spoiler: show
- Donor 2020
- x 53
Re: xantia rescue
Scottculli That offside strut does look dodgy, remember not to get underneath the car until it's properly supported on ramps or axle stands as the suspension can squash you if it drops suddenly. It looks/sounds like a low pressure leak which is easier to sort then a high pressure one .....
Slowly and safely .....
- x 6
Re: xantia rescue
oh definitely iv got 4 jacks, a trolley jack and just for safety im gonna put a tyre underneath, after seeing how low the suspension goes when de pressurised im not gonna take anything to chance on that.Skull wrote: ↑15 Dec 2020, 21:08Scottculli That offside strut does look dodgy, remember not to get underneath the car until it's properly supported on ramps or axle stands as the suspension can squash you if it drops suddenly. It looks/sounds like a low pressure leak which is easier to sort then a high pressure one .....
- Donor 2019
- x 210
Re: xantia rescue
The leak on the N/S strut seems to be coming from the return feed looking at the picture.
The pipe and brackets are still available i think from Citroen and can be found on the inter web and are actually quite cheap but can be a pain to fit correctly ( well for me any how ).
Will try and dig out my post about my leak from the N/S front strut return pipe
Colin
Found the Link
Colin
Found the Link
- x 1278
Re: xantia rescue
Odd coincidence - our interwebby pipes went off today so put the TV on, first time in four years, to watch "His Dark Materials" - which starts at 20:10.
Was early so had a look at the menu and "Diamonds Are Forever" was on - halfway through and the scene above came on after about ten minutes - I had no idea that it was from that film.
When it finished I turned over to watch HDM and of course that was just finishing too, on an hour early tonight.
Those JB films are pretty hokey really.
- x 6
Re: xantia rescue
hey everyone hope you enjoyed your holidays . I've finally had some time here where the weather hasn't been rainy and a clear schedule.so the last couple of days iv had the car up on axle stands and crawled underneath to try and find out where the leaks where coming from, I've found the location of two leaks, the first one was at the front left of the engine bay where the pressure regulator and the control block ,it didn't take to long to find roughly where this one came from as the was a huge puddle of lhm in the battery box my first culprit is this hose I didn't try to find out which one it was yet as the was so much fluid loss I didn't want to try to put any pressure through the hydraulics with that little fluid, but ill get some soon and it wont be hard to find the culprit, the second leak was hard to find, this was underneath the nearside of the front subframe and it dripped all the way down this cover(I'm not sure what its call thought) .my first enquiry was to se if the break doser was leaking but from the top of the engine bay the where no puddles dripping down from where I could see, so this one left me a bit puzzled as I'm not sure how I would find this leak and was wondering if any of you guys had dealt with this one, as its a bit peculiar just because its really hard to look up into the engine bay from underneath, but anyway I'm looking forward to your replies, my next objective is to find the culprit to the leek in the battery box, speak to you all soon, and have a happy new year
- Donor 2020
- x 53
Re: xantia rescue
Scottculli Good news that LHM+ is very clean
which is a good sign that it was looked after before being parked up.
A short static run shouldn't harm the system and is often the easiest way to find the leak
That hose with the kink doesn't look standard to me (especially with those connectors)
Good Luck ....
Good Luck ....
- x 6
Re: xantia rescue
I think you might have a point on that hose being makeshift , as i do remember it just sliding off easily when i was cleaning the battery tray, it may explain the leak,if someone has just used a temporary fix for the return line with non lhm resistant hose which over time has caused it to perish.it would definitely make sense,Skull wrote: ↑29 Dec 2020, 21:19Scottculli Good news that LHM+ is very cleanwhich is a good sign that it was looked after before being parked up.
A short static run shouldn't harm the system and is often the easiest way to find the leak![]()
That hose with the kink doesn't look standard to me (especially with those connectors)![]()
Good Luck ....
- x 433
Re: xantia rescue
That hose near the battery tray is definitely not correct. Something else looks strange in that photo, but I can't pick what it is, I will see if I can find a similar photo of another car.
The other leak could be anything, maybe LHM spilled while filling the tank?
- x 1494
Re: xantia rescue
The kinked hose is the return from the power steering pressure regulator valve mounted down on the LH chassis leg... It's definitely not supposed to be kinked like that...
The LHM looks well clean!
- x 6
Re: xantia rescue
Ah a photo would be great it would help give me a understanding on what the repair should look like. but with the other problem, it reminds me more of a leaky tap.when the engine is on after a couple of minutes a small puddle starts to form just lowly dripping of the subframe, just in front of where the drives feet would be, ill get a picture of it so I could explain it better, just its in a bit of a awkward place,xantia_v6 wrote: ↑29 Dec 2020, 23:44That hose near the battery tray is definitely not correct. Something else looks strange in that photo, but I can't pick what it is, I will see if I can find a similar photo of another car.
- x 6
Re: xantia rescue
I was thinking it was weird that the hose was kinkd,because it allways got in the way whenever i took the battery out,and it didnt seem like something citroen would design .i dont think the original fluid would look as green as that, but when I got the engine running and tryd to put it through a thew cycles going up and down,the fluid in the reservoir would plumit so I would top it up, sorry if that was a bit weird I probably should have explained,so all that stuff on the battery tray would be new. I was wondering what type of hose can you get thats lhm resistant? Would you be able to use fule line as a replacement, or would that be to much of a temporary fix.
