Everything else seems to work when the power steering doesn’t operate- lights, radio etc.
The only other unusual thing is the alternator which is faulty (low voltage) when tested in the car but works fine when bench tested.
Power steering failure
- NOT Alistair or Simon
- x 1184
Re: Power steering failure
I wonder if anybody has checked the various cables and their connections?
- x 2240
From what you've just said, it's possible that your wiring may be faulty from the alternator to the battery, or the battery terminal connections, which would make sense if it is working on the bench but intermittently on the car. Another good reason to have an auto electrician check the circuit out thoroughly.Natasha_Young wrote: ↑21 Dec 2020, 14:03Everything else seems to work when the power steering doesn’t operate- lights, radio etc.
