Lockdown Vintage Audio Activities...
- Donor 2021
- x 1462
Re: Lockdown Vintage Audio Activities...
Unfortunately, I've never seen or heard this particular one working, but considering it's current state, that's not surprising
- Donor 2022
- x 615
Mine wasn't quite as big as that.
Nice pair of KT66's
- x 2012
A bit bigger than my first amp - a Philips 2½A valve amplifier. Had to be operated with the top off so that the RH channel valve could receive a finger flick to start it. About 8"x4"x4".
- x 1467
Where was that rack monster installed, Bobins?
- Donor 2021
- x 1462
The old central Govt. War HQ, though I think it predates that !
- x 1467
So - all part of a thermionic nuclear end to life as we knew it.
I wonder which eight gramophone records would have been standing by?
- Donor 2021
- x 1462
The PA system associated with the War HQ is a much much smaller bit of kit - it's a tape based one that sits on its own on a shelf. That hasn't worked for years either, but I did get to hear it work years ago, and even then it sounded decidedly wonky !
I've got a photo of some of the gramophone records from the old PA system somewhere. If I can find the pics I'll post them up later.
- x 1789
Hell Razor5543 wrote: ↑17 Jan 2021, 17:47As I said on your Instagram feed, that looks like a main line battle tank should be bolted to it!
I think the Grampian is possibly tougher and better armoured than the average tank
Bobins, interesting stuff
It certainly was some very good kit Richard and always highly respected...
Another very famous company and highly respected Chris... Their kit is very sought-after by collectors these days.white exec wrote: ↑18 Jan 2021, 13:42Clarke & Smith held sway in schools right up to the '70s, most famously for LW/MW (and later FM) radio receivers, with 100v line output, which was conduit-routed to all classrooms.
All of us of a certain age remember it from our schooldays - maybe that's the reason so many have such an affection for it
- Donor 2021
- x 1462
Here's the four speed gramophone player that would have entertained the masses. You can choose from 16, 33, 45, 78 rpm speeds.
And the last few of the records that I know of that were played on the PA system. You'd just have to hope that whoever chose the records wasn't a Val Doonican fan
- x 1789
That record deck looks very familiar Bobins
Those broken records are 78s I guess... Hope you turned the stylus over before playing them
- Donor 2021
- x 1462
Apparently it's a BSR UA14.
I'll try and track down those records next time
- Donor 2022
- x 615
I remember those.
- x 1789
- Donor 2022
- x 615
They used to bounce a lot when the records dropped Jim, needed some dampers.
- Donor 2021
- x 1462
Jim - a nice little restoration job for you and Peter.......
