C4 I directional headlamp ECU
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5719
Re: C4 I directional headlamp ECU
You'll have this if you have SEDRE - those designations are the PIN numbers in the 32 bit connector concerning the comms and power. I haven't included all the ones from the headlamps themselves or the height correctors as these won't be relevant given that the lights are working and that your issue is a communication one to and from the ECU - so that will either be because the ECU is not powered up, not earthed or the CAN wiring is faulty I suspect.
- Cutac
- My Cars: 2011 B7 Citroen C4 1.4 VTi
2006 Citroen C4 2.0 VTS - x 20
Problem solved, it was the fuse. But for some reason, the manual that came with my car shows a different fuse layout. Fuse F6 was the culprit, but my manual says it's a fuse for the automatic transmission (which I obviously don't have).
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
I didn't mention the fuse as F6 was listed for Halogens and Auto Transmission as you said - but that's typical of PSA!
- Cutac
Can't believe it!
But hey, all that matters is that my headlamps work properly now
Thanks for your help, Marc!
