Airbag, Dashboard, Seat Belt & Airbag ECU Repairs
Forum News, Announcements and any issues you're having with the forum
Moderator: myglaren
Huskyxantia
Donor 2021
x 72
Re: Airbag, Dashboard, Seat Belt & Airbag ECU Repairs
Post by Huskyxantia »
Ive got esp abs comes on when i drive about 20 to 50 yards
The whole abs sensors are new complete new brakes new rear wheel bearings with senor ring built into types,
I clear the code test drive lights back on, was wondering if the brake pedal switch could be the problem.
x 2985
Post by GiveMeABreak »
We'll really need Peugeot Planet on it to get the specific fault codes, then post them up.
Huskyxantia
Donor 2021
x 72
Anyone know the best cable to use for abs looms ?
Huskyxantia
Donor 2021
x 72
The problem is a wire to rear left sensor heres what i have done.
Probed all the sensors there all good probed the loom everything good apart from one wire rear left .
Unplugged the plug from the abs mod probed each pair of wires and same readings all good apart from the rear left , so its down to a wire, a break in the loom, and guess what its under the exhaust and a heat sheild... so im almost there.
Huskyxantia
Donor 2021
x 72
Thought id add this as i thought it was for the rear abs its to the rear speaker.
This isn't abs loom its for the rear speaker
Huskyxantia
Donor 2021
x 72
All sorted, 4 wires on the abs loom plug, cut out the old broken wires new water tight connectors both rear wires then closed up the female connector pins all put back together 20 yard drive all lights off and still off , car now has new MOT
Huskyxantia
Donor 2021
x 72
Huskyxantia wrote:
01 Nov 2021, 16:45
Wrong it is for the rear abs sensors !
