Sphere Check & Suspension Questions 1999 Xantia Break 2.0i 16V
- My Cars: Xantia Break 2.0i 16v 1999
- x 3
Re: Sphere Check & Suspension Questions 1999 Xantia Break 2.0i 16V
Front spheres replaced, acumulator sphere replaced, they came of quite easily all from above, no need to go under car using the chain clamp. Drives like a dream now, real flying carpet action and the clicking has almost completely stopped, it clicks maybe once every 3-5 minutes or so. Still got the new rear spheres sitting in the backseat will tackle them when I go out to the cabin, there I have a setup that allows me to easily work from under the car, this is lovely 10/10 finally I get to experience what driving a Citroën is all about.
- white exec
Result! That's great news, and good to rediscover the proper Citroen ride.
Well done for seeing it all through.
- Lexia Available: Yes
- My Cars: 605 V6 SII
406 D9 SV
Xantia SX wagon SII
Xantia Activa TCT (unregistered) - x 217
No doubt you've read up on this - but for the sake of others reading this thread I'll state the bleeding obvious...larsy93 wrote: ↑29 Jun 2020, 19:32 Front spheres replaced, acumulator sphere replaced, they came of quite easily all from above, no need to go under car using the chain clamp. Drives like a dream now, real flying carpet action and the clicking has almost completely stopped, it clicks maybe once every 3-5 minutes or so. Still got the new rear spheres sitting in the backseat will tackle them when I go out to the cabin, there I have a setup that allows me to easily work from under the car, this is lovely 10/10 finally I get to experience what driving a Citroën is all about.
When doing the rears you will of course start by setting the suspension to it's lowest setting, then leaving the engine running for a couple of minutes until it has completely settled onto the bump stops. This obviously ensures that it cannot collapse on you. So you need some way of being able to get under the car when at it's lowest - a hoist, ramps or a pit.
Then undo the special pressure release bolt on the regulator about 1/4 turn, or until you hear the whoosh of the pressure escaping & fluid returning to the reservoir (but no more than one full turn, or you risk the spring and ball bearing escaping ). When pressure is fully released the rear wheel cylinders (which the rear spheres are screwed into) will actually be a little bit loose.
I also have a Series II wagon or break - it doesn't look as nice as yours, but it is a great reliable workhorse. I gave it a new set of spheres last year, and it now rides very well.
Cheers
Alec
- xantia_v6
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 833
On a Xantia (or BX or XM) you MUST initially loosen the rear spheres with the suspension set to the highest setting, to lock the cylinder against the frame. Otherwise there is a good chance that the cylinder will twist and damage the metal pipe. Once the sphere is undone 1/8 th turn, then select the lowest setting with the engine idling for at least a minute to release the pressure before (optionally) releasing the screw on the regulator.
