no electrical power
- white exec
Re: no electrical power
Check also the main battery connectors. If either one gets at all warm (or hot) after trying to crank, there is a bad connection there.
A cold diesel engine will draw roughly around 250-300 amps from the starter motor but as said above the headlamps will probably draw less than 10 amps so your knackered battery may have enough capacity to operate lights, wipers, radio etc but nowhere near enough to start the engine
You’ve not answered the previous questions about the voltage dropping under load & attempting to jump start?
- My Cars: Citroen Xhara
I tried putting a 15 volt small battery charger on it for a week this time as it has more voltage then the other one.
I put the multi meters on the battery and turn the key and all I can hear is a relay clicking under the dash (no wippers or lights this time) and the voltage on the battery drops to something like 5V
- white exec
A jump start from a known-good battery, or another vehicle, will tell you whether your battery is dead or not.
If the jump start is successful, buy a new battery.
- Donor 2023
- Lexia Available: Yes
- My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff] - x 378
Just to add my issues to this thread .
Yesterday my Xantia decided it would not start, i have been doing 70 miles a day for the last 18 months in it, yesterday it refused to start, jump started it from the C5 no issues, but battery was showing 12.4 v and could not pull the skin off a rice pudding. New battery aquired today and fitted fired up like a new baby and she is 20 years old
- Donor 2023
Voltage and Amps are very different animals and live within the battery
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
A scruffy analogy is that the volts carry the load, but the amps are the load.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
You need a new battery.hoppington wrote: ↑20 Jul 2020, 12:48I tried putting a 15 volt small battery charger on it for a week this time as it has more voltage then the other one.
I dont know anyone with a motor car round hearwhite exec wrote: ↑20 Jul 2020, 14:00 A jump start from a known-good battery, or another vehicle, will tell you whether your battery is dead or not.
Well if you defo think it the battery then I will go out and buy a new onewheeler wrote: ↑24 Jul 2020, 10:26You need a new battery.hoppington wrote: ↑20 Jul 2020, 12:48I tried putting a 15 volt small battery charger on it for a week this time as it has more voltage then the other one.
- white exec
That is probably the best option.
When you fit the new one, thoroughly clean the main battery connectors where they clamp on the battery terminals.
If either battery connector gets at all warm (or hot) when cranking the engine, there is a bad connection there. If they are the original lead (Pb) lumps, these deteriorate with age and are best replaced with new solid brass clamp-type connectors.
Im pretty sure Xsara Picassos never used lead type battery clamps.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
They're not lead on my Sister's XP and being inside under the passenger seat have a little more protection from the elements.
