Got jack via ebay while back cheap enough as most going for daft money!
With Rattler it meant crankshaft didnt move so if held together by? it didnt move timing cog
If in doubt just give the vin number to the seller, I'd be thinking a 6 rib pulley , it was a while back when I removed a pulley and I had the car on stands , a long bar ( heavy duty bar) put it on the pulley with socket of course and wedged it toward the ground and had it the way facing that undid the bolt when quickly turning the ignition key , it worked for me just need to be confident enough not to let The engine fire fully up , when you take the pulley off don't lose that D piece , and when you see how and what the pulleys are made like then your see why they failoscar wrote: ↑31 May 2020, 14:47 Hi have what believe is crankshaft pulley failing starting little noise now clack clacking away like an old diesel!
Did notice while back it looks bit up n down wonky! Did think about other bits like idler,Alternator,Aircon but rev sound isn't quite right as they revolve at different speeds?
Garage/Tyre gaff went to other day to balance wheels said Pulley and Mechanic mate that works on PSA Vehicles said yep when said noise and don't go too far as can take cam belt out!
Now looked at so many pulleys could see them in me sleep!. found ones for Pug 206 diesel £20 yet wanted £36 of xsara but when looked through a list fits either can more!
Are they all the same if162mm extrernal 6 rib?
Hi maybe a week etc too late for that as all done and dusted. Makita DTW285 18v rattled bolt out without moving crankshaft.Huskyxantia wrote: ↑19 Jun 2020, 09:36If in doubt just give the vin number to the seller, I'd be thinking a 6 rib pulley , it was a while back when I removed a pulley and I had the car on stands , a long bar ( heavy duty bar) put it on the pulley with socket of course and wedged it toward the ground and had it the way facing that undid the bolt when quickly turning the ignition key , it worked for me just need to be confident enough not to let The engine fire fully up , when you take the pulley off don't lose that D piece , and when you see how and what the pulleys are made like then your see why they failoscar wrote: ↑31 May 2020, 14:47 Hi have what believe is crankshaft pulley failing starting little noise now clack clacking away like an old diesel!
Hi well the Dam FEBI failed Only done around 300 miles this evening got the re flash of death once in a while then more then once went to load steering up was heavy found a spot had a gander aux belt came off.lexi wrote: ↑06 Jun 2020, 07:51Yes, one belt rib hanging over each side of pulley. Febi is decent. Last Febi thing I bought for C5, had Dayco stamped on it, so all good stuff.oscar wrote: ↑05 Jun 2020, 23:10One i got is a Febi one(red&white box)looks same as one onit already! but was wondering about rib count this one has 5.Belt looks like 7 but guess have one either side on outside of pulley ribs so makes sense?
They sure don't make it easy esp atmo with things trying to get help/info from them!
Seller is a spares place not in there Bedroom!
