It's kind of similar to the old key pad system fitted on earlier models, if you input the code to unlock the ECU the disconnect the keypad when it is unlocked the ECU will stay unlocked forever, even if the battery is disconnected or ECU is unplugged. The locking time delay varies depending on whether the door has been opened or not, cant remember how long it is but i know its quite long if the door has not been opened/closed.JohnDragonMan wrote: ↑31 May 2020, 01:45 ohh interesting. i was not aware that it was on a time delay. i would have thought that it would have locked down (so to speak) when all power was disconnected (taking off the battery connector)
Anyway here is what i have compiled for the CPH pin allocations, please update if there are positions with no wires or unallocated.
15 way Black
Pin 1 - Permanent live
Pin 2 - Indicator output
Pin 3 -
Pin 4 - Permanent live
Pin 5 - Ignition live (unfused)
Pin 6 -
Pin 7 -
Pin 8 - Central Locking trigger
Pin 9 -
Pin 10 - Indicator output
Pin 11 -
Pin 12 -
Pin 13 - Earth
Pin 14 - Central Locking trigger
Pin 15 - Output to interior lights
26 way Yellow
Pin 1 - Door open switch (Right)
Pin 2 -
Pin 3 - Door open switch (Left)
Pin 4 -
Pin 5 - To lock/unlock switch in door motor (Left)
Pin 6 - To Engine management ECU (Joined with pin 7)
Pin 7 - To Engine management ECU (joined with pin 6)
Pin 8 - To pin 3 of transponder aerial
Pin 9 -
Pin 10 -
Pin 11 - To pin 11 of diagnostic socket
Pin 12 - To pin 5 of transponder aerial
Pin 13 -
Pin 14 -
Pin 15 -
Pin 16 -
Pin 17 -
Pin 18 - To lock/unlock switch in door motor (Right)
Pin 19 - To Engine management ECU
Pin 20 -
Pin 21 - To pin 1 of transponder aerial
Pin 22 -
Pin 23 - To pin 4 of transponder aerial
Pin 24 -
Pin 25 -
Pin 26 -
