Hi Marc, VIN number as requested: VF3**************[VIN obfuscated, can be read by forum staff] Peugeot 3008 1.6hdi Exclusive 2010
Peugeot 3008 2010 MyWay RNEG issues
Moderator: GiveMeABreak
- My Cars: 2010 Peugeot 3008 1.6hdi exclusive
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Peugeot 3008 2010 MyWay RNEG issues
The RNEG system in your car does not have 2 FM aerials, so the FM2 connection on the diagram (a) should be unused on your original RNEG head unit.
So the FM/AM and GPS aerial is connected to the roof aerial via a long cable to the dashboard, that has a separate harness that it plugs into. This smaller harness then provides the connectors to the back of the RNEG unit. So in your case a single FM /AM for radio and a second connector for GPS.
So going back to your issue, your aftermarket Head unit may have a separate AM aerial connection. Try connecting the FM aerial into the AM connector at the back of your aftermarket unit and see if you can get AM reception (after retuning the head unit). If that works, then you may have to get a splitter to separate the FM/AM Aerial into 2, so you can plug the other part of the split into the AM connector.
I can't see from your enlarged image the other connections as they seem cut off to the right.
Many thanks Marc
