E10 on its way
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1380
Re: E10 on its way
Presumably a similar source as the band INXS had?
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Re: E10 on its way
That always looked like Inkses to me
- NewcastleFalcon
- x 6888
Re: E10 on its way
Yes I think that hits it on the head Paul. GTL gas to liquid, CTL Coal to Liquid , and BTL Biomass to Liquid are well used acronyms in synthetic fuels, so as the feed source for XTL synthetic diesel can be either renewables or fossil material or a mixture of both, the X bit is unspecified. The EU's European Committee for Standardization labeling info does state that XTL stands for synthetic diesel and indicates that it is not derived from crude oil.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
Re: E10 on its way
XTL - Crystals to liquid - made from fairy dust.
- van ordinaire
- (Donor 2017)
- Location: Live & work in London but weekend in Devon (or do I now live in Torbay & work in London?)
- My Cars: Citroens:-
'81 2CV Club (quietly sleeping in a parallel universe)
'05 (yes, really) C15
'97 Xantia Exclusive estate
others:-
'96 Jeep Cherokee Limited - the "donor"
'99 Jeep Cherokee Orvis - the green one
'97 Jeep Cherokee Limited - the red one
'99 Cadillac Seville STS
'96 Cadillac Eldorado ETC
& numerous what might be described as abandoned projects! - x 405
Re: E10 on its way
thus squaring the circle - & returning to "E"
Citroens:-
'81 2CV Club
'05 C15
others:-
Jeep XJ Cherokees x 3
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- xantia_v6
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
Re: E10 on its way
Not very much...NewcastleFalcon wrote: ↑09 Mar 2020, 19:27 There is a bit of E85 "Super Ethanol" in France, about 1000 pumps in 2018 if my translation of this is right
https://ethanol.ovh/stations-superethanol-e85/
Good old E.Leclerc seem to have it at some of their outlets.
Now for a bit of colateral knowledge gaining.....what do the French do with it?
It has been a commercial failure. Some new cars (including some PSA models) are available with a flexi-fuels option, but it seems that very few have been sold.
There are also conversion kits (of varying quality) avialable for most common engine types, I considered converting one of my Citroen V6s, but the nearest E85 pump is 50 km from where I live in France, so not really a viable option.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
Re: E10 on its way
Dollywobbler investigates.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
Re: E10 on its way
Just filled up with what purports to be E10 (Sainsburys). Seems OK but only driven a mile from the petrol station
Will be a while evaluating, MOT and service tomorrow and son will have the car back on Tuesday until the end of the month, after which it is going on holiday to Wales.
Almost washed it but then common sense* prevailed.
*laziness.
*laziness.
- bobins
- Donor 2023
- My Cars: Kia Sportage
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2893
Re: E10 on its way
It's extremely easy to remove the ethanol from E10 petrol (or indeed E5 if you want) at home - you just need some suitable containers and some water. Whether everyone would do it safely and whether the "But what if....?" health and safety crowd would be happy is another matter
Sadly no longer a C5 owner
- mickthemaverick
- My Cars: 70+ former cars (list available) including 11 Citroens, 3 Renaults
Current cars: 2004 Subaru Legacy 2.5 SEn, 1994 Mazda MX3 - x 6066
Re: E10 on its way
I'm sure that is the case bobins but wouldn't that be swimming against the tide? Surely the object of increasing the ethanol is to reduce emissions so surely removing the ethanol would put the emissions back to where we don't want them to be?bobins wrote: ↑18 Jul 2021, 13:56 It's extremely easy to remove the ethanol from E10 petrol (or indeed E5 if you want) at home - you just need some suitable containers and some water. Whether everyone would do it safely and whether the "But what if....?" health and safety crowd would be happy is another matter
- bobins
- Donor 2023
Mazda BT-50
Land Rover SIII SWB
V-F-R800
SL320
MX5 - x 2893
Re: E10 on its way
I can see some of the reasoning behind adding ethanol, but being as it contains less 'energy' than straight petrol, you need to burn more of it for the same power output. You also have to take land out of food production to make the plants to make ethanol. There's also the degrading effect it has on older vehicles - there is a balance point between scrapping an old banger because its time has come and the ethanol has tipped the balance, and having to spend extra money to keep a half-decent classic going because it's feeling the effects of ethanol. I can see the reasoning behind running cars with ethanol in towns and cities - less so for rural areas. As Dollywobbler says - putting ethanol in petrol shouldn't be the answer, getting people to drive less should.
A lot of the small engined machinery I use definitely suffers from moisture in the fuel which causes carb issues. I try to reduce the problem by running the carb dry when I've finished, and if I lend kit out I ask that it be returned with as near an empty fuel tank as possible. I've had to clean out many people's carbs for their small engines as water has sat in the fuel and corroded them.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
Re: E10 on its way
There may be a case for removing the ethanol and bottling it but only if it were a cheaper way to get it than buying vodka.
As long as the car runs I don't care.
I used to have a problem with water getting in to the tank on a Hillman Imp and used to add meths to 'soak up' the water.
- NewcastleFalcon
- x 6888
Re: E10 on its way
The pump handle says one thing, the chatty bit of paper says something else, so not entirely sure whether BB Micra received its first drink of E10 or not or whether it doesn't arrive until Sept 1st
The gov.uk website gives the 2005 BB Micra this assurance
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
Re: E10 on its way
Mine said E10 last fillup, 31st July.
Perhaps just preparing - or scaring.
- NewcastleFalcon
- x 6888
Re: E10 on its way
E10 on its way, today's the day it officially arrives although the pumps at Sainsbury's have been labelled up for a while now.
Dont think Nissan are taking too many risks saying that E10 is compatible with their 15 to 20 year old engines. If it knacks up the 16 year old BB £100 Micra doing 4,000 miles a year, I'll not be signing up to a class action lawsuit.
