New toy with issues
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4921
Re: New toy with issues
Post by myglaren »
As they use Phosphoric acid, perhaps a splash of that would do the trick?
Amazon have it.
moizeau
My Cars: 91 BX TZD Estate. Dead but loved
407 HDI 136 auto
C4 2l petrol coupé
2010 Dispatch III HDI 90
AND a 1980 Z1000ST
AND a 1983 GPz1100 inj
AND a 1995 Zephyr 1100
AND a 1980 Z650 (my moped)
x 315
Post by moizeau »
Looking at the Deox Gel followed by Hydrate 90 on the Bilt Hamber site at the moment. Both have excellant reviews. I want to stay away from acids....'cause I'll underneath getting dripped on.
Pete
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
x 4921
Post by myglaren »
Bilt Hamber is the name I can never remember, as you say, it comes very well recommended.
RPWC
My Cars: Former Citroen owner.
x 21
Post by RPWC »
As Chris has said Finnigans has now been taken over by Akzo Nobel. The factory when it WAS Finnigans was just outside the village I grew up in. Back then it was just 2 big wooden garages, then it moved to its current site which used to be the ICI paint factory a couple of miles to the east at Eltringham, between Stocksfield where I come from, and Prudhoe. It was initially owned by a family from the village, but was sold in the early 80s I knew of Allen Forster, but didn’t know him personally, I do know his eldest son though.The company now trades as Hammerite Products, Prior to Hammerite, they used to do a rust proofing substance that was sprayed on called Waxoyl. The advertising was Finnigans Waxoyl stops the rust.
Here endeth the forum history lesson.🤣🤣🤣
https://www.hammerite.com/history/
Cheers Rich :wink:
moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
x 315
Post by moizeau »
My dad bought me a tub of Waxoyl when I bought my first car, that and a BOL.
Pete
My Cars: 1996 XM 2.5TD Exclusive hatch RHD
and lots of Rovers before that: 1935 Ten, 1947 Sixteen, 1960 P5 3-litre, 1966 P6 2000, 1972 P6 2000TC, and 1975 P6B 3500S
x 1752
Post by white exec »
You can make your own waxoyl-like goop with white spirit, a bit of grease, and a lot of old (or new) candles.
Oh - and a fire extinguisher! :sprint:
If you use a lot fewer candles (and no grease!) you have a very effective tent waterproofing treatment.
RPWC
x 21
Post by RPWC »
What’s BOL?
Cheers Rich :wink:
Donor 2023
Lexia Available: Yes
My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone)
x 1379
Post by Paul-R »
Book of Lies = the workshop manual.
"Trying is the first step towards failure" ~ Homer J Simpson​
x 1752
Book of Last resort?
moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
x 315
Post by moizeau »
Mini update, I think all the products are good, but checking shipping etc I've gone for 2 litres of Fertan. Also used by people with narrow boats. Hopefully on the 11th I can go to a mates place with a pit and get the wire brushes out.
Pete
x 1752
Take great care with Fertan, Pete.
It contains phosphoric acid and heavy metal compounds, and has a pH of 1.4∼2, which is extremely acidic.
Eye and skin protection essential.
MSDS sheet is online (Fertan rust converter MSDS).
RPWC
x 21
Post by RPWC »
Keep the updates coming Pete, I like to follow the progress.
Cheers Rich :wink:
moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
x 315
Post by moizeau »
Thanks very much Chris for the heads up. I didn't realise. I presumed it would be relatively safe due to the blurb stating it's water based and can be sprayed. Googles and gloves it is then. I will certainly read the safety notice for all products I buy from now on and not trust the sales definition.
Will do Rich.
Pete
moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
x 315
Post by moizeau »
Right then, I've found another issue. First noticed it last week when coming down the motorway with another poorly toy in the back. It's the first time I've driven over 60mph, normally I sit at the 80kph speed limit and don't accelerate hard. The issue is that it doesn't like being above 3000rpm under load. It's like it's panting / gasping rhythmically every 3 secs. Don't know if it's gasping for air of fuel. On the motorway I was in 5th at about 70mph going up a hill, just now in 4th at 60 going up a hill. I revs freely in the 1st 3 gears. It starts fine, pulls well from 1000rpms in 3rd (don't know if this is normal) but does seem to run out of torque and will just hold 50mph in 5th up a steepish hill at 2200rpms which I would expect to be it's 'sweet spot'. I think I may have noticed this 'panting' just off idle in 2nd when the van has just started, i.e. when I'm creeping up the lane putting my belt on. I'll plug it in to see if there are any codes but if I was to induce this, in 4th, where would I look for clues in the live data?
Tootling around you wouldn't know anything was wrong. I've no idea if it accelerates normally for a 90hp 1.6 because I've got nothing to compare it with, but I would say 'it's not nippy'.
Any pointers gents will be much appreciated.
Cheers
Pete
moizeau
407 HDI 136 auto
C4 2l petrol coupé
AND a 1980 Z1000ST
x 315
Post by moizeau »
Plugged Diag in, no errors. The actuator arm moves about a cm when the car is started, it can also be pressed in manually. Went for a run, same problem in 4th as mentioned above but by keeping my hoof down I could drive through it. Looked through the live data. The only thing that sticks out is the turbo pos'n indicator stays at 100% and the ref value moved from 43 to about 47%. I've got some mercury gauges for balancing the carbs on my bike and wondered if I could rig these up somewhere to check the vacuum. Also I believe the turbo was changed when Rich had it and wondered how to check it's been set up. I read somewhere that you put a known vacuum on it and the actuator arm should move a certain distance?
Has anyone got a picture of the mounting for the vacuum solenoid, a mates got a pit. I'm thinking about taking it off and cleaning the foam filter.
Cheers
Pete
Post Reply
