As I’m driving down the road I can hear what I can only describe a WUH WUH WUH rubbing kind of noise (rotational) coming from the front end which seems more noticeable when turning corners/rounding bends, along with a separate, louder, constant droning noise from the rear which is only noticeable from 35mph and over. Had 4 new budget directional tyres fitted a couple of months ago and the droning noise started a couple of weeks after that.
Any ideas what either noise could be please anyone ?
Trying to identify a noise
- x 1240
Re: Trying to identify a noise
Could well be the tyres although I mostly use budget tyres with no problems. Otherwise it could be a noisy wheel bearing. You could try swapping the front tyres to the back and see if the noise moves with them.
- x 1985
Jack each wheel off the ground and spin it....
