Picasso possible next car
Huskyxantia
Donor 2021
x 72
Re: Picasso possible next car
Post by Huskyxantia »
One day the rear wipe works another it won't ....
Roll on better weather for a proper investigation. I've noticed if the tailgate is shut hard the rear wiper will work.
Huskyxantia
Donor 2021
x 72
Update :
I've removed the motor today and noticed the white plastic part the power cable plugs into has movement so I've wrapped it with black electrical tape powered the motor up and its working and has been since.
Also taped around the wiper spindle to tighten the spindle as it slides back in and that stops any possible water getting in.
I also noticed too the wires that connected to the rear demister was at one point earthing , that is also cured with The same black tape , all good now.
Huskyxantia
Donor 2021
x 72
Rear wiper still working as it should looks like the black tape has done the job :)
Huskyxantia
Donor 2021
x 72
Still working as it should !
Heat shield over exhaust has been damaged due to the storms and floods so I've that to sort but after falling down the stairs yesterday morn thanks hip that can wait
Huskyxantia
Donor 2021
x 72
GiveMeABreak wrote:
13 Jan 2020, 00:04
Yes, tights as a crab's ar*e - same as our C3.
Started the timing belt job today it is tight the angle of the wing is a bit of a pain aswell
Huskyxantia
Donor 2021
x 72
Huskyxantia wrote:
28 Jan 2020, 10:54
Oops just seen a nice xantia on eBay
Note to self ... No No No ...keep what I have
Huskyxantia
Donor 2021
x 72
Doing timing belt today I got as far as its ready for the pulley to be lined up and locked then the tensioner to be slackened off for belt to come off and so on
I need the torque settings for pulley, water pump bolts and so on , any one have the numbers , thanks in advance .
Huskyxantia
Donor 2021
x 72
Above.
Water pump 15/15lbs nm
Crankshaft bolt 196lbnm +. 50° tighten then.
Idler 18lbnm
Tensioner 10-18lb nm
