Picasso possible next car
- Huskyxantia
- Donor 2023
- My Cars: Past cars
Xsara Picasso 2019 to 2022 r.i.p
Xantia mk1&2 1.9D & 2.0Hdi
Peugeot 206 sw 1.4hdi
Other models
Skoda fabia,escort van,ford ka,Vauxhall astra g car & estate, Vauxhall corsa b, Suzuki swift
Escorts mk 1,2,3,4,5 fiestas mk 1,2, Sierra diesel mk1 Mondeo mk1 diesel .
Peugeot 207 , 307sw
Now cars
Picasso 2.0Hdi now gone to scrappie
Citroen zx estate 1.9D the cherished one
Peugeot 206cc raised from the dead & saved from the crusher traded up to a 308cc
307sw traded for the 207 .
Wish list.
Peugeot 405 diesel
106 or 206
Mondeo Mk1 diesel once owned 1.8tdi was real nice. - x 423
Re: Picasso possible next car
Is this the correct part for my bus ?
https://www.ebay.co.uk/itm/153470297923
Husky.
'13 3008 1.6 HDi GripControl - x 996
Should be, there only appears to be one part no for the whole of the production run...
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Good makes it a lot easier , my xantia had same issue same side but they had colour coded plugs which is why I didn't know if Picasso was the same.
Thanks for that
Thanks for that
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
No hand brake warning light on dash and a slightly dim LCD display
2 small panel bulbs replaced easy fix.
Then I found the hand brake needed the metal part the warning light switch sits in pushing back about 4mm .
This then allowed the switch to operate as intended and illuminate the dash warning light.
Cheap fix that took all of 5 mins
Just the rear door lock motor to replace when that arrives and the rear wiper issue (working on own)which is making me think , checked wires first for damage multiplex wiring ??
Waste money on another motor or bung it up after removing it , where to get the bung from ??
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Anyone know the signs of a suspect relay ?
Wire to the rear wiper motor is fine I unplugged the loom from the wiper motor and found the live popped a bulb tester on the plug and the bulb lit up BUT not a regular pattern as if the wiper would sweep .
The relay ticks and here's what got me turning of the switch the wiper did 3 complete sweeps after it was as I said turned off, I noticed pushing down on the wiper spindle it would make it work WITH IGNITION OFF !!!
Any suggestions , maybe get another relay ?
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
If I was a 20 something I'd consider remapping But ... If its road worthy and gets me to where I need then im happyMichel wrote: ↑11 Jan 2020, 20:04One can get a remap up to 123bhp and enormous torque, as I did.with my 04 plate 2.0HDi Berlingo 0-60, genuinely, timed on an app at 8.9 seconds and remarkable in-gear pull.
I'm currently "looking after" a 2.0 HDi Picasso, 03 plate Exclusive. Mate dropped it off for me to sort out in May 2018... it's still here, still reliable and I've done 10,000 miles in it
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Update if anyone's interested .
Testing the rear door lock motor has confirmed loom is fine lock is dead .
Replacement part sourced and will be fitted within the coming days weather permitting.
The whole car has been deep cleaned and looks a whole lot better.
The rear wiper motor has been unplugged for now , have sourced a replacement which comes as a kit , apparently there brackets are held in by special rivets which had to be drilled out and replaced with normal bolts with washes and nylock nuts.
Wiper stalk is ok and by the sounds the relay ok as well plus loom
This has to be a wiper motor failing as its doing the very same as what my xantia did when I had that.
Husky.
Scrappy for a wiper motor then?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Try the BSI reset first of all to clear any BSI niggles (unless already done recently).
Although the battery is under the front passenger seat, there are remote positive and earth blocks under the bonnet located at 'b' below. I'm not sure from memory whether these have a release to disconnect one or the other - or whether they are used just for measuring purposes / jumping.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
was just having lunch and received a notification from here , Glad I've logged in I think I will do this reset I did read this morning its like rebooting the laptop thanks Marc for the diagram very helpful indeed I'll try with what I've read and then post back what happens, if you hear a loud bang an see smoke then we live closer than we think hahahaha....GiveMeABreak wrote: ↑14 Feb 2020, 12:15 Try the BSI reset first of all to clear any BSI niggles (unless already done recently).
Husky.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
With the storm brewing up, I went out this morning to retrieve the food bin and nearly ended up in the Outer Hebrides.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
OK here we go , pointing toward a relay now
I did the full reboot, I did a dry run first to make sure I got it right plus I had to plug the motor back in.
So here's what I'm getting .
Switch back wiper on it wipes 3 times.
Then nothing till I turn it off it wipes 3 times again , start engine up clutch down select reverse it wipes ( even when switch is off) and that's normal as far as i understand
I've no intermittent wipe for the rear the relay clicks when turning on The rear wiper and clicks when its turned off with Tue accompanied 3 wipes ..
So it looks to me as if the relay can't do the intermittent part ... Looked at the loom last week and its fine.
The reboot was easy enough and when I switched my side lights on a nice loud tone was heard.
Husky.
- Huskyxantia
- Donor 2023
Other models
Peugeot 207 , 307sw
Now cars
Wish list.
Peugeot 405 diesel
106 or 206
Getting windy here and colderGiveMeABreak wrote: ↑14 Feb 2020, 13:18 With the storm brewing up, I went out this morning to retrieve the food bin and nearly ended up in the Outer Hebrides.
Husky.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
The rear wiper action varies according to vehicle speed. Here's a little info...
The table below gives the intermittence timings of rear wipe as a function of vehicle speed and of windscreen wipe speed.
Vehicle Speed (V)
In the mode: Stop or PVI, there is no automatic rear wipe.
Key:
The BSI protects the rear wiper motors against overheating in the event of blocked torque, irrespective of the operating mode requested by the user.
The protection timing for both the windscreen and rear screen wiper motors is 7 seconds.
Vehicle Speed (V)
Decreasing speed | Increasing speed | Stop or PVI | Intermittent | PV | GV |
Speed<5 km/h | Speed<10 km/h | 0 s | 5 s | 5 s | 5 s |
5<speed<40 km/h | 10<speed<50 km/h | 0 s | 10 s | 10 s | 10 s |
40<speed<80 km/h | 50<speed<90 km/h | 0 s | 15 s | 15 s | 15 s |
Speed > 80 km/h | Speed > 90 km/h | 0 s | 10 s | 10 s | 10 s |
Key:
- PVI: Intermittent Slow speed
- PV: Slow speed
- GV: High speed
