Ok, so there is a maximum operating temperature of 850 °C and a maximum permissible temperature of 900 °C for both the Upstream and downstream temperature sensors (1343 Downstream & 1344 Upstream on the previous electrical circuit diagram). If you are getting 1271 °C, then the sensor is at fault I suspect.
Again - check the wiring harness for a break / heat damage.
Peugeot Boxer, fault codes and turbopressure
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Peugeot Boxer, fault codes and turbopressure
