Misty Mornings with 2020 vision
- My Cars: '95 Xantia 1.9D automatic - 118k one of two? remaining
'97 306 1.6 XS, 24k, The ex-Haynes "Max Power" display car. Bought after being written off & stripped, now being rebuilt without the wide body
'96 ZX 1.9TD SX, 81k new resurrection project saved from the scrapper - x 216
Re: Misty Mornings with 2020 vision
My view at 8:59 this morning..... Alarm never went off so were late for school run!
- Attachments
'97 306 XS 1.6i, Blaze Yellow, 24k
'96 ZX SX 1.9TD rolling shell, White, 81k
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Do you live in the land of eternal darkness?
OnlinePaul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1381
A black cat in a coal hole at midnight?
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
You were looking out your window the morning before the Big Bang was due to occur?
Nope, I have got it.
- Spoiler: show
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- mickthemaverick
- My Cars: 70+ former cars (list available) including 11 Citroens, 3 Renaults
Current cars: 2004 Subaru Legacy 2.5 SEn, 1994 Mazda MX3 - x 6066
I reckon that's copied from my Armageddon post a few weeks ago!!
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
A completed one of these?
Or this taken to the extreme?
Haha nothing so complex, simply the back of my eyelids! oops, managed to get laddo to school just before half past though!
- white exec
Winched across from POTD, by request...
This is an evening shot from our terrace, out across Torre del Mar bay, with Gibraltar in the distance.
The maximum distance you can normally see to the horizon is 3 miles - from ground level for a 6-footer.
Up where we are (406m above sea level), you can see 24 miles.
Gibraltar is 90 miles away . . . so how can we see it?
Usual Big Prizes for the answer
A few more...
Sea mist sweeps in And Spain from underneath...?
A few more...
- mickthemaverick
Would it be anything to do with the fact that the Rock is 426m high and the horizon distances are the distance limited by the curvature of the earth but raised objects will be visible from further away? (I can't be bothered to do the sums ) but heres a diagram of the principle:white exec wrote: ↑13 Jan 2020, 10:02
- Donor 2023
- x 3008
Mirage refraction? Taking the picture from a higher than normal elevation? You are using a drone with a decent camera at a much higher altitude?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- white exec
Mick hits the basic geometry: go higher, and you can see further round the curve.
But that's not the reason.
Mirage? No. It's the real thing.
But on the right track.
Clue: Seeing Gib 90 miles away is only possible near sunset.
- Donor 2023
- x 3008
A mirage is caused by light bending as it passes through air of differing temperatures. The clue (that it only occurs near sunset) would suggest this is likely. Does it happen more often after hot days? If it does, what could be happening is that the ground has become very hot during the day. As cooler air moves in during the evening it is warmed by the ground, allowing a refraction more parallel to the ground (a normal mirage is where the air is hotter than the ground causing a reflection of the sky to appear on the ground). If this is the case it would explain why Gibraltar can been seen when it is, in fact, too far around the horizon to be seen in normal conditions from that altitude.
If I am right then the air is, in effect, behaving like a fibre optic strand to allow the view of Gibraltar to become visible.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- mickthemaverick
Does that mean it involves sunlight from a lower level in the west casting the "shadow" up into your eyeline or maybe refracting off the atmosphere?
- white exec
Spot on.Hell Razor5543 wrote: ↑13 Jan 2020, 14:53 A mirage is caused by light bending as it passes through air of differing temperatures. The clue (that it only occurs near sunset) would suggest this is likely. Does it happen more often after hot days? If it does, what could be happening is that the ground has become very hot during the day. As cooler air moves in during the evening it is warmed by the ground, allowing a refraction more parallel to the ground (a normal mirage is where the air is hotter than the ground causing a reflection of the sky to appear on the ground). If this is the case it would explain why Gibraltar can been seen when it is, in fact, too far around the horizon to be seen in normal conditions from that altitude.
As the sun goes down, the air at higher altitudes cools quickly, and is temporarily sitting on top of warmer air near the ground - the warmed ground radiates heat into the air immediately above it.
This means that the air near the ground is less dense (warmer) than the air higher up (colder), and the density graduation behaves just like a lens - it bends the light.
Rather than the "bent stick" effect seen when a pole sticks out of the surface of water, where there is a sudden change of density (at the water-air boundary), the change of density of the air at sunset (after a warm day) is a progressive one - nothing sudden - and so it bends light in a curve.
So, light emanating from Gibraltar towards the observer doesn't go off onto space in a straight line, but is curved downwards by the colder air. In that way, you can "see over the horizon".
Virtual beer tokens!
- mickthemaverick
Every day's a schoolday!!!
